Convertible roof problems code c2364
Old Jun 22, 2020 | 01:06 PM
Infinitiyauco's Avatar
Infinitiyauco
Hello, I have a 2010 Infiniti g37 convertible and the convertible roof does not close, it only makes a beep beep, when I drive it constantly stays beep and on the screen it shows roof in operation until I stop, I saw some videos that indicate that it must be given a relearn , I took him to a mechanic, he gave him a relearn but a c2364 code comes out that he does not want to delete and I do not know what it is,the mechanic told me battery is about to die but still starting the car little vague but work fine until now,in other posts that I read change the battery for a new one works only for about 3 weeks and then start the problem again, i don't know if apply to my case,someone who has happened the same thing that tells me what to do please since I want to avoid taking it to the dealer because it very expensive,there will be somewhere where all those codes are found? Thanks in advance
Old Jun 29, 2020 | 04:08 PM
teahead's Avatar
teahead
I have the same problem, only the roof is stuck in the DOWN position.
At the dealer now. I'm hoping that 3rd-party extended warranty I bought for it covers it.
How old is your battery?
Get a new one and try it again.
Old Jun 29, 2020 | 04:16 PM
teahead's Avatar
teahead
Old Jun 29, 2020 | 06:30 PM
teahead's Avatar
teahead
Just got it "re-learned".
Not bad. $175 at the Nissan dealer, I'm ok w/that.
teahead's Avatar
teahead
B1763 code. Interesting.
Old Jun 29, 2020 | 08:06 PM
Infinitiyauco
I'm glad you solved your case, in my case I put a new battery in it and nothing, question, is deleting the code the same thing that relearn? because one mechanic couldn't erase it and the other one erased it and it doesn't do anything either, I'm going to have to take it to another mechanic because in Puerto Rico where I live the infiniti dealer has 30 minutes left and they don't work the convertibles, they refer them to another place that is 2 hours driving,,wish me luck
Old Jun 29, 2020 | 08:09 PM
teahead's Avatar
teahead
Erasing the code does squat.
You have to go to a dealer and get it relearned unfortunately by THEIR computer.
Try a Nissan dealer. That's who fixed mine.
Old Jun 29, 2020 | 08:25 PM
Infinitiyauco
Ok ,I'm going to do that,thanks
Old Jul 10, 2020 | 01:30 PM
Infinitiyauco
Hi teahed,i fix my car yesterday at a nissan dealer,cost me 220.10 I'm ok with that too ,hope it last long time because electrical parts not have warranty,thanks for the advice
Old Aug 5, 2020 | 11:30 PM
teahead's Avatar
teahead
GODDAMMIT!
Went over a big pothole that I couldn't avoid.
Guess what...I'm back w/the "Roof in Operation" error w/the loud beep! Who'da thunk a big bump would now cause that again!
Another trip to the dealer and $200 down the drain.
Old Aug 6, 2020 | 12:09 AM
Infinitiyauco
Hi,since they fixed the car on July 10 2020, just check that the roof worked that day and since then I have not come back down, I think I am a little afraid that it will be damaged again, I may lower it later but for the moment I'll leave it with the roof up, I hope you can solve
Old Sep 22, 2020 | 09:49 PM
GFlake's Avatar
GFlake
You need the sensor $200. Tells the computer where the top is at all times
solved all my problems
Old May 23, 2022 | 03:36 PM
RFRMIL's Avatar
RFRMIL
What's the sensor called? And where is it located
Old May 25, 2022 | 07:42 AM
Trevbrontemaki's Avatar
Trevbrontemaki
does anyone know if you can disconnect the beep mine is stuck in the up position? mine says in operation but garage says new hydraulic system, thank you for any help its driving me made the beep
Old May 25, 2022 | 05:04 PM
n559br's Avatar
n559br
You can pull the hydraulic pump easily enough yourself and send to top hydraulics. $400 fix.
