Convertible Top does not work...
Old Jul 25, 2019 | 10:59 AM
jobono69's Avatar
jobono69
HELP!!!!.. My wife left the passenger seat all the way up and the seat headrest would not allow the passenger side top to close completely leaving a gap of 1 inch. The driver side did closed completely (the top from the driver side closed and the passenger side was semi-close with a gap of 1 inch). I had a mechanic looked at it and he was able to close it manually (don't ask me how...) because it was raining and I didn't want the inside to get wet. Anyhow, now the top would not open nor close. I tried disconnecting the battery, but it didn't work. Do you guys know if the top can be open manually or can I disable the hydraulic pump so that they can access the mechanism which is in the trunk, but the trunk doesn't open either because the system says that the roof is in operation. Please HELP!!. I am in NYC, if someone knows a place around NYC that can fix it, please let me know.
Old Jul 25, 2019 | 07:11 PM
Fins160's Avatar
Fins160
After disconnecting the battery, ensure you hold the roof closed button for at least 10 seconds to perform a reteach.
Old Jul 25, 2019 | 08:45 PM
jobono69's Avatar
jobono69
How long do I have to leave the battery disconnected? Thanks for your reply
Old Jul 25, 2019 | 08:54 PM
Fins160's Avatar
Fins160
At least 5 minutes to reset the computer.
When you reconnect, you'll need to reset the top by holding the top close for 10 sec.
Also you'll have to reset your windows. Pull the power window switch and hold it to close the window, and then hold the switch more than 3 seconds after the window is closed completely
https://nicoclub.com/archives/retimi...-moonroof.html
Old Jul 25, 2019 | 09:22 PM
jobono69's Avatar
jobono69
After reconnecting the battery, do i have to turn the car on to reset the top?
Old Jul 26, 2019 | 12:26 AM
Fins160's Avatar
Fins160
Yes, it should be on (engine running).
1HOTG37S
Jan 10, 2021 11:01 AM
Matty_baby
Picture Share G Coupe
21
Feb 6, 2019 03:09 AM
JustinH
G37 Convertible
Aug 29, 2018 09:31 PM
baldwin_ng
Apr 16, 2010 07:33 AM
