headliner replacement
Old Sep 8, 2018 | 12:01 PM
SF25's Avatar
SF25
While closing the top of my 2011 conv, it took a big bite our of the headliner in the lower right side. the dealer said 3k to replace the headliner but three local shops have all said around $300.00 to replace the headliner. Anyone have experience with this issue. thanks
Old Sep 8, 2018 | 12:27 PM
sidestepca's Avatar
sidestepca
do it yourself. its farily simple, just requires the fabric and some adhesive fabric spray, and jus work the material.
Easily can cost you under $50 if youre willing to do labor
Old Sep 15, 2018 | 04:04 PM
kiseliok's Avatar
kiseliok
G37 Community Team
I think this one is a little more involved than a standard coupe / sedan as it has a few bendable / flexible points that need to be properly secured.
I wouldn't trust myself with this one, but I can't imagine why a reputable shop wouldn't be able to help you.
Old Nov 3, 2018 | 02:13 PM
Cadmandu's Avatar
Cadmandu
Didn't have a fabric tear, but had the tension string break. It was a fairly easy fix, just a little time consuming. I just looked at the other side an copied how it was rigged. I would check every avenue before replacing, that is extremely expensive, hopefully your tear is minor and you can get a local inexpensive fix.
NIGHTLFEphantom
30
Sep 7, 2008 09:35 PM
solopresident
Sep 7, 2008 05:43 PM
ChimChimG37
Jun 23, 2008 04:44 PM
99m3
Nov 27, 2007 01:21 PM
