Seat Belt Loop Fail
Old May 26, 2013 | 01:37 AM
James Spearman's Avatar
James Spearman
Seat Belt Loop Fail
Hi,
The loops attached to the seat to control the seatbelt have failed - basically the platic and leather around the clasp have ripped, see the pictures
Has anyone else had the same problem in which case what has been done to repair it?
I asked infiniti to fix under warranty but they say it was due to excess force - this is really don't agree with as the failure has happened around the metal ring around the clasp. Finally i wouldn't "Force" excessively to pull a leather strap on a car i worked so hard to buy!
Any ideas on a repair and has anyone else experienced this?
Attached Thumbnails Seat Belt Loop Fail-loop1.jpg   Seat Belt Loop Fail-loop2.jpg
Old May 26, 2013 | 11:23 AM
bschurr's Avatar
bschurr
Bummer!
I havent seen or heard of that before but, that should be an easy fix for an auto upholstry shop, convertible repair shop or perhaps even a shoe repair shop to correct.
Good luck!
Old May 26, 2013 | 12:23 PM
colnajoe's Avatar
colnajoe
I only have one snap which makes me think with one it can rotate and move with the movement of the belt. With two snaps its stuck in one spot. Is the angle of the belt in the loop a sharp angle, putting stress and strain on the snap and loop itself? I used to think the two snap set up was better for helping the belt retract, but not now.
Old May 26, 2013 | 11:49 PM
gsqrd's Avatar
gsqrd
I have this same problem on my 12G vert. Service advisor says they will fix but I was waiting till oil change. He is gone from dealership so who knows if they will honor his commitment. Mine failed as you described. i was opening the loop in usual fashion and it ripped.
Old May 27, 2013 | 09:15 AM
zdubin's Avatar
zdubin
It's a very lame setup, they should have gone with a plastic loop the the belt could be slid in and out of. The Volvo C70 has a much slicker setup.
A car upholstery place should be able to repair this easily. Ask your dealer for the person they use. I doubt this would be very expensive to fix.
Old May 28, 2013 | 05:09 PM
Sinecure's Avatar
Sinecure
Seems to me they should cover under warranty. But if not, try a cobbler.
Old Jun 4, 2013 | 12:47 AM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
This. Really excessive force? Call infiniti consumer affairs if you are still under warranty.
Old Jun 4, 2013 | 03:08 PM
Fezzik's Avatar
Fezzik
^^^^ This is exactly what I would do. The snaps are designed to come apart and back together not rip off.
Old Jun 5, 2013 | 07:16 PM
gircal's Avatar
gircal
Go to a marine supply store and buy replacement snaps and replace it!
fuzzed
Aug 21, 2020 09:35 AM
Rybitron
Nov 18, 2015 03:11 PM
RexHavoc
Oct 2, 2015 11:47 AM
Bennyjoel
Sep 30, 2015 11:56 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
