Seat Belt retraction fix is available
Old Apr 21, 2011 | 02:38 PM
blueninjabron's Avatar
blueninjabron
This is a safety issue
I had the same issue with my seatbelt not retracting and you can tell the dealer that if you get in a accident and the seatbelt fails, they will be looking at a huge lawsuit. The much cheaper options is for the dealer to replace anything that has to do with the seatbelt before you get in that accident. The dealer I took it to replaced everything without questions and told me that seatbelt is a safety issue and should be replaced anywhere.
Hope that helps.
Old Apr 21, 2011 | 04:09 PM
cvipgo's Avatar
cvipgo
Hope that helps.
fyi:the convertible's seat belts have no safety issue- just don't retract fully post unbuckling... they just hang which allows the buckle to hang, can get caught between seat side and door panels which dents the door panels...
otherwise they work fine when buckled up.
Old Apr 24, 2011 | 12:11 AM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
So I'm getting mine replaced i.e. the seatbelt mechanism and full door panels on both sides. Parts have been ordered.
Old Apr 29, 2011 | 09:04 AM
newspider4re's Avatar
newspider4re
great service at don rosen
I had the G in for it's 15k service and told them about the TSB for the belts and they have ordered the parts and replacement door panel and rear seat panel. Very impressed.
Old Apr 29, 2011 | 09:56 PM
cvipgo's Avatar
cvipgo
The replacement seat belt retractors/tensioners makes a big difference, belt buckle goes up all the way out of the way, I had mine replaced today.
Old Apr 30, 2011 | 02:40 AM
cereal2k's Avatar
cereal2k
can't wait to get mine
Old May 1, 2011 | 11:39 AM
g37vanbc's Avatar
g37vanbc
Can someone that has had the TSB done posted the part numbers used?
My dealership in Canada is being **** about it saying there is no part numbers listed on the TSB so how to we know what parts to order and all this BS.
Old May 2, 2011 | 03:48 AM
stevelam's Avatar
stevelam
my dealership in edmonton just ordered the belts from the 2011 G vert i think they told me, they called infiniti parts support for info. my doors are fine so there not replacing them.
Old May 2, 2011 | 11:52 AM
bschurr's Avatar
bschurr
I had my door panels & belts replaced last week. My service adevisor noticed them and called ahead to have the reapirs authorized under warranty. It only took a day to receive the parts.
I'll post up part #s from my service report when I get home...
Old May 2, 2011 | 01:29 PM
cereal2k's Avatar
cereal2k
It's in the beginning of the thread, post 8
https://www.myg37.com/forums/3100708-post8.html
Old May 6, 2011 | 08:17 AM
bschurr's Avatar
bschurr
sorry for the late reply - I totally forgot.
Anyway, here are the part #s from my service receipt:
Driver's side:
BELT ASSY-TONGUE, PR-86885-JJ63B
FINISHER ASSY-FRONT-80901-JJ51B
Passenger side:
BELT ASSY-TONGUE, PR-86884-JJ63B
FINISHER ASSY-FRONT-D-80900-JJ70B
and they noted the following on the bottom of the service invoice:
"**NOTE SEAT BELTS MUST BE INSIDE LOOPHOLES ON FRONT SEATS IN ORDER TO PREVENT DAMAGE TO DOOR PANELS"
Old May 6, 2011 | 01:00 PM
cvipgo's Avatar
cvipgo
I had only following parts installed with modified side finishers per ITB11-012 with no note or warning and I use seat belt cushion going thru the seat loop. Works great.
Driver's side:
Passenger side:
Old May 6, 2011 | 02:27 PM
bschurr's Avatar
bschurr
Driver's side:
Passenger side:
I think that is just the belts not the door panels...
Old May 6, 2011 | 02:37 PM
  #29
cvipgo's Avatar
cvipgo
I didn't need door panels, mine are pristine as new..
Old May 6, 2011 | 02:48 PM
  #30
cereal2k's Avatar
cereal2k
If your lower door panels are damaged, mention it and they will replace them.
I did not get the handles removed but I will ask about it as it's a little scratched up.
