FS 2008 G37s 6MT - Arizona
Year: 2008
Make: Infiniti
Model: G37 Coupe
Price: $18500
Mileage: 77000
Color: Black
Location (State/Prov): AZ
Price Reduced to Final Price of $18500
Obsidian Black G37S
Factory Viscous Limited Slip Differential
8-way Heated Power Seats
Telescopic Steering Wheel
Factory Navigation
Factory Bose Sound System
Factory Rear Spoiler/Backup Camera
Sport Package
Infiniti Trunk Mesh Net
Infiniti First Aid Kit
Premium Package
Sport Front Bumper
Front/Rear Infiniti Sport Package Big Break Kit; recently changed the brakes with stop tech street pads all around with drilled rotors front/back.
Clutch/lightened flywheel was changed recently when the slave cylinder went bad. Slave cylinder was replaced with the Zspeed metal CSC and a new master was put in at the same time, Zspeed CSC also comes with braided clutch lines.
Clutch/Flywheel are Southbend the SuperStreet package.
RJM Clutch pedal was installed which makes the car drive much smoother than the stock setup.
Tranny and Diff fluid were swapped with Redline fluids at the time of the clutch change and clutch fluid was swapped with Motul fluid.
Rays Engineering Volk G2's 18x9.5 Front 18x10.5 rear wrapped in BF Goodrich G Force Sport Comp 2's in 255/45/18 front and 275/40/18 rear.
Stock 19's will also be supplied but have no tires attached.
Lugs and Locking Lugs included are Muteki burning blue aluminum.
Oil changes have always been synthetic and car runs perfectly.
All documents and receipts received during the cars ownshership will come with the car.
The bad:
The stock hood shocks have gone and are extremely expensive from the factory so I just use a prop to hold it.
Stock Rear bumper was cut slightly to allow the quad exhaust which is no longer with the car.
Reason for sale:
I need to clear debt so I can apply for a house, nothing is wrong with the car mechanically whatsoever.
