Auto Lock / Unlock Mods, Window Mods, and VDC Mods for June 11th
FGC Central Florida BOD
Auto Lock / Unlock:
With rpm: 110 installed, 100 without install.
Without rpm: 80 installed, 70 without install.
1. lexicon (how much for rpm based add-on?)
2. Skyline04 (how much for the 6 second locking mod?) PM me
3.
Window Mod: 65 installed, 60 without install
1.
2.
3.
VDC Mod: 55 installed, 45 without install
1.djniknala
2.
3.
3.
1.
2.
3.
1.djniknala
2.
3.
finiti you still wanted the window mod right? since you have an 05 if you enable the auto locking of it you will not be able to pull the handle like us 03 and 04 guys. you will have to hit the unlock button to opent he door. but that is easily fixed with the auto lock and unlock mod. since it will unlock the doors as soon as you turn your car off.
I'm only having you install the shock sensor for now. I was thinking about the roll-up mod, but since I'm photophobic too
and I pretty much never roll my windows down, I'd rather get the auto lock/unlock mod instead. I have that feature in my other car and I really miss it in the G, I highly recommend it to everyone. However, it's very likely that I'll be out of mod funds due to my pending clear bra install, so don't put me on either list yet.
The window module will work IF you can raise your windows by holding the key in the 'LOCK' position in the drivers door cylinder. I have installed a window module in an 02 maxima but I cannot guarentee that it will work for all trim levels! Also, when you put the key in the door cylinder, if the windows do go up ONLY the windows that go up at that time will be controlled by our module. On some Nissans its only the front two windows, while in others its all four windows.
The window roll up module is a simple 20 minute install. Most of the time is spend removing and reinstallling the door panel. You just use a blue wire splice and hook it right up. Daniel can give you more info, but the directions are VERY straight forward.
What year G do you have and is it a coupe or a sedan?
Auto Lock / Unlock:
3. skyline 05
1. skyline 05
2.
3.
1. djniknala
2. skyline 05
3.
3. skyline 05
1. skyline 05
2.
3.
1. djniknala
2. skyline 05
3.
cconklin2
Jan 9, 2016 07:21 PM
