Eibach springs on stock 19's (pic)
Old Apr 17, 2006 | 12:51 PM
  #31
Gilley's Avatar
Gilley
Florida G35 Club, General Member
Originally Posted by Foo_G
did you do the camber arm on the front or camber kit on the rear
No, it's all stock.
Old Apr 17, 2006 | 01:00 PM
  #32
Foo_G's Avatar
Foo_G
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
hmmm. so when you dropped your car it stayed within spec?
did you do an alignment immediately after the lowring?
Old Apr 17, 2006 | 01:59 PM
  #33
WILD121's Avatar
WILD121
I was trying to remember when Omi owned his G and I couldnt remember. Thats because I wasnt here yet
Old Apr 17, 2006 | 02:02 PM
  #34
WILD121's Avatar
WILD121
Thats bc he has the Htechs they drop your car with in stock specs. So you dont have camber issues. If you get the stec then you will need camber arm toe bolt A arm. Eibachs I think you need all the stuff to fix your camber caster Toe....blah blah blah blah.
Old Apr 17, 2006 | 02:31 PM
  #35
Foo_G's Avatar
Foo_G
hmm that is food for thought thanks.
I will look up the HTechs. thnx
Old Apr 17, 2006 | 02:38 PM
  #36
Foo_G's Avatar
Foo_G
dang looks like a bigger drop in the front with the htech and a slightly smaller drop in the rear.
Old Apr 17, 2006 | 02:42 PM
  #37
SFLG35's Avatar
SFLG35
FGC Central Florida BOD
when mike had his eibach's he didnt have any camber correction equipment. his rears were just out of spec as well as the fronts.
steve now has the springs that were on mikes car and it looks as if he couldnt get the rears in either so he would just need to get the rear camber and toe arms. id imagine steves fronts are yout too but the price of the front a arms is also a lot higher so most people dont get them.
i will probably have my kinetix front arms up for sale when i get to the spc ones to test out. if anyone would like them let me know.
  #38
Foo_G's Avatar
Foo_G
yikes the stechs are a real set of snow plow springs.
Old Apr 17, 2006 | 02:45 PM
  #39
Foo_G's Avatar
Foo_G
Dan so are you saying he was not very far out of spec on the eibachs?
oh so you are the spc tester . They sound very nice and I cant wait to see how these turn out.
Old Apr 17, 2006 | 02:48 PM
  #40
Foo_G's Avatar
Foo_G
someone just listed some stechs for 60bux in the classifieds . whoa tha si cheap and says they are new.
Old Apr 17, 2006 | 03:06 PM
  #41
SFLG35's Avatar
SFLG35
they could be counterfeits
there are some that are goin around claiming to be real. check out tein's website.
Old Apr 17, 2006 | 03:11 PM
  #42
Foo_G's Avatar
Foo_G
dang.. conterfeit spings holy cow! That would certainly explain the price.
Old Apr 17, 2006 | 03:17 PM
  #43
Foo_G's Avatar
Foo_G
I hecked the website. Man that is crazy. They must have had some serious issues with this in order to make an effort like that to warn the public.
Old Apr 17, 2006 | 04:49 PM
  #44
WILD121's Avatar
WILD121
Yeah Becareful.......
Old Apr 17, 2006 | 04:53 PM
  #45
WILD121's Avatar
WILD121
what kinda of a drop are you looking for? Depends on the kind of springs you want. More aggresive get the S tech if you want to stay with in stock spec get the H tech. It sounds like you dont want the hassle of camber, toe and caster issues so I would get the H techs. As Dan said the Eibach put your car just out of spec so you would need a camber arm in the rear and maybe an A arm in the front. Listen to Dan he knows his stuff.
