Anyone have a idea whats wrong my brake/vdc/slip light are on!
happened to me a month ago, kept coming on and off periodically.
decided to seek help from the dealership and my local autoshop and they discovered i was long overdue for new brake rotors/pads.
some people here on the forum will insist your brake fluid must be low but I'd get the pads checked by the local autoshop (or yourself) just in case.
this just happened to me when i got my camber kit installed. it is possibly 1 of 2 things - either your speed sensor bracket is bent or it is simply misaligned. if you have messed with your front assemblies then this is most likely the cause. if they came on all of a sudden, then scuba is probably right.
as long as it doesn't mess up the warranty I'd strongly recommend getting it done at the local shop if they're reliable and fair. got my transmission fluid changed, back rotors refurbished and front rotors replaced along with the brake pads for $550 at the local place. Dealership quoted me $850...just puttin that out there.
same thing happened to me
redlinernyc
Feb 29, 2016 11:06 PM
