Adding to my crazyness....
Old May 30, 2006 | 03:34 PM
  #31
Audible Mayhem's Avatar
Audible Mayhem
Performance Factory
i love it!!!!!!!
Old May 30, 2006 | 03:44 PM
  #32
djniknala's Avatar
djniknala
Mafs work by running air over a hot wire. The voltage it takes to keep the wire hot is the voltage sent to the computer. Different mafs have different airflow tables ie, 1.4v on one maf might not be the same cfm as another maf even if they were in the same diameter tubing. The maf housing also plays a roll because the larger the housing the less velocity and therefor less air will be metered by the maf. The computer simply takes these maf voltages along with the other engine parameters most notably IAT(intake air temp) and uses this to determine Injector Pulse Width. This is all under full(or near full) throttle. In this way the computer cannot adjust itself because under full throttle it no longer looks at the O2 sensors and this is the only way to see how the combustion event(or how rich or lean it was) turned out. Hope this made sense.
Originally Posted by JaxGman
My question is, the whole point of a MAF is to meter how much air is being flowed into the intake, and that tells the computer how much fuel to put into the motor, shouldnt the computer adapt to this when replacing the maf? Jeremy and I had a long convo bout this mod, and why he is seeing such great results...
Wow, 50% driveline loss. What kind of trans do you have? LOL.
5 hp for just a maf swap its pretty good.. figure thats bout 10 flywheel horsepower
Old May 30, 2006 | 03:56 PM
  #33
Audible Mayhem
Performance Factory
it must be american made!!
Old May 30, 2006 | 03:57 PM
  #34
Gilley's Avatar
Gilley
Florida G35 Club, General Member
So now I have to figure out how to do the leaf blower + NOS mod.
Old May 30, 2006 | 04:03 PM
  #35
dabomb's Avatar
dabomb
FGC Central Florida BOD
i think Jeremy does free installation on other peoples car without signing a wavior....
Old May 30, 2006 | 04:07 PM
  #36
JaxGman's Avatar
JaxGman
Makes lots of sense... of course when u r wide open your puter is on a open loop and goes by the preset tables in the computer. But it all comes into more air, more fuel more power. Thats why tuning after a mod is so critcle.. IAT is HUGE part of everything.. haha
5AT LOL.... Just hypin up the mod.. Gonna slap JDM badge on it... sell it for 800 bucks and claim it makes 10 HP..
Old May 30, 2006 | 06:58 PM
  #37
djniknala's Avatar
djniknala
Didn't know if you knew what open loop was but since you do then you know that is the point that it stops looking at the stock NB O2. My car goes into open loop at around 65% TPS. I don't have much experience with the newer cars with WB's so they might be a little different.
Makes lots of sense... of course when u r wide open your puter is on a open loop and goes by the preset tables in the computer. But it all comes into more air, more fuel more power. Thats why tuning after a mod is so critcle.. IAT is HUGE part of everything.. haha.....
Old May 30, 2006 | 10:03 PM
  #38
JaxGman's Avatar
JaxGman
Everything i know is from my Mustang.. i was just learnin to tune it and all that when i fugged up a rod.. damn that Meth injection... (pump stayed on and filled intake full of windshield wiper fluid) but it went open loop around 70 percent, my IAT out of the blower was 240 degrees YIKES... we added the meth/water injection kit.. got it down to 110 and added a bunch of timing and made 60 more to the wheels..
Old May 30, 2006 | 10:08 PM
  #39
SFLG35's Avatar
SFLG35
i thought i recognized that dyno then i started to look at the person who was holding the leaf blower and then i realized thats eric from cpracing. thats pretty funny.
those guys are hilarious when you meet them in person.
Old Jun 2, 2006 | 09:33 AM
  #40
k_hojnacki's Avatar
k_hojnacki
I'm really interested in this mod and love all the source information. My question is without a UTECH or comparable add-on computer, what would the outcome be by just increasing the MAF size with the just the stock G35 computer? Will it make the car run lean or rich? By adding a Pop-charger or other air box, doesn't that in essance also increase the air flow (or at least velocity) through the MAF?
Old Jun 2, 2006 | 10:12 AM
  #41
JaxGman's Avatar
JaxGman
I dont think u should need a UTECH for this mod, but being able to tune your car will get the most out of every mod you install.. as for me UTECH will probably be my next mod for this reason.
Old Jun 2, 2006 | 01:36 PM
  #42
Audible Mayhem
Performance Factory
the car would misfigure the fuel and lean it out by over 10% and thats not good. your AF would be in the upper teens at best...
the maf sensor is 2.75 inches around, the sensor reads how much air runs through it cause it knows exactly how much air can go around it through a 2.75 inch tube. increasing that tube lets more air go around the sensor and not through it therefore it will read as less air going into the engine and add fuel for less air...
Old Jun 2, 2006 | 01:38 PM
  #43
SFLG35's Avatar
SFLG35
jeremy i just called you
Old Jun 2, 2006 | 02:03 PM
  #44
JaxGman's Avatar
JaxGman
Ahh.. just put race gas in it and be done with it!!
Old Jun 2, 2006 | 05:46 PM
  #45
k_hojnacki's Avatar
k_hojnacki
So, with that figure in mind, is there a larger MAF sensor, say 3" from any other Nissan of Infiniti that would also fit our VQ engines that might correct this issue? And more specifically, from the highly technical community, what size MAF sensor should we be looking at for a 75.5mm housing? Is there a 2.86 inch or comparable MAF sensor available?
