Alternative to Service at Dealership?
Old May 19, 2006 | 08:22 PM
john5220's Avatar
john5220
I just had my 15k service done at the dealership...and got a sheet showing what is performed at 30k.
what I noticed more than anything is that for an additional $645 over the cost of the 15k service, the dealership will:
flush tranny fluid
replace engine coolant/flush system
replace engine drive belts
replace differential oil
replace radiator cap
adjust headlights if necc.
assorted inspections.
Seems like an awful lot of $ for this amount of work!!!
This brings me to the question: Is there a shop in the Orlando area that folks here have used as an alternative to the dealership? And if so, how satisfactory was the experience?
I would assume this service not done at the dealership would NOT void the warranty!
Let's not even about the 60k service which adds a spark plug change and replace upper/lower rad hoses for an additional $400!
Somebody shoot me!
Old May 19, 2006 | 08:27 PM
papagz's Avatar
papagz
you can get your work done at any shop as long as you have records of it. they cannot void your warranty for that. as long as it shows you have had the services done
Old May 21, 2006 | 09:34 PM
Gilley's Avatar
Gilley
Florida G35 Club, General Member
The dealership will have their "recommended" service and then what Infiniti calls for, which is substantially less. Aome of the service is easy to do on your own to save money, such as changing the in-cabin air filter.
Old May 21, 2006 | 09:42 PM
Foo_G's Avatar
Foo_G
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
If you do not have the shop manual you might want to subscribe to alldatadiy.com. You can save a ton doing your own work
fuzzed
Aug 21, 2020 09:35 AM
delfinparis
Nov 16, 2015 02:26 PM
Junchao Sun
25
Oct 1, 2015 12:41 PM
MrRiv
Sep 29, 2015 04:59 PM
