Engine, Intake and Exhaust Subforum dedicated to breather or engine mods (intakes, exhaust, pulleys, N/A mods etc.)
Help CAT replacement TP or HFC
Old Feb 9, 2023 | 01:57 PM
Qusai Rayyan's Avatar
Qusai Rayyan
Hello Everyone
I have a g37S convertible 2013, the car had some rattling noise in the exhaust so the mechanic said its the catalyst and he remove the filling so the car can run smoother, the car is having weird smell which is expected withing the filling of CAT.
so I need your help to choose between HFC or TP or keep it as it is.
1- I hated the smelll of car with the current hollow CAT, will the Test pipe have the same smell ?
2-will the test pipes make the car sound better than the hollow CAT or HFC ?
3- Best tp and HFC to consider with reasonable price.
I have only Takeda CAI and this will be my second afermarket part what shiould be my next change to have cooler exhaust sound and better performance?
Old Feb 9, 2023 | 02:08 PM
Your car has two catalytic converters, one each side. I'm assuming your mechanic didn't just gut the one, right? Either way, you're probably getting a CEL because of this.
Test pipes or gutted cats... same thing, same smell. Get high-flow cats. Better yet, get resonated high flow cats.
IDK what's on today's market anymore, can't advise about that.
Old Feb 9, 2023 | 03:25 PM
Qusai Rayyan
I did little research i found Berk resonated sound pipe for 350 USD and it does not create a fault code, cheapest HFC is 550 and no resonated version.
What do you think should i install next ?
Old Feb 9, 2023 | 04:48 PM
Sway bars (any brand) and 3-season tires.
Old Feb 10, 2023 | 03:08 PM
BULL's Avatar
BULL
Moderador
If you dont like the smell you probably wont like the rasp included with the test pipe, even resonated.
Your best choice will be resonated HFC.
VQCrew
Intake and Exhaust
Nov 26, 2019 10:48 AM
Skribblz
May 20, 2015 12:04 AM
gtracing
Intake and Exhaust
Aug 30, 2012 08:05 PM
SoFloG37
Intake and Exhaust
Sep 26, 2008 11:39 AM
PSYH
Intake and Exhaust
19
Jul 25, 2008 10:51 PM
