Engine, Intake and Exhaust Subforum dedicated to breather or engine mods (intakes, exhaust, pulleys, N/A mods etc.)
Review Fumoto Oil Drain Valve
Old 03-15-2018, 01:00 PM
Baadnewsburr
Baadnewsburr's Avatar
Originally Posted by NW_6MT
[left]Don't think I explained it very well. You pull off the clip (1 second) and lift and twist the lever 90 degrees (1.5 seconds). No tools, no mess, no oil on your hand as you're making that last few turns to remove the drain plug and trying to dodge the stream of hot oil.
lol ok cool, I get it now...interesting piece for sure, but FWIW not for me. I'm gonna stick with good ol'bolty McBoltface that's just me though...
Old 03-15-2018, 01:05 PM
NW_6MT
NW_6MT's Avatar
Originally Posted by Genhero
I installed a fumoto drain valve on my lancer a few years back. It hung below the engine crossmember which made it the lowest point to bottom out.
This is another consideration on our cars. Luckily the drain plug points to the side of the oil pan. I wouldn't put a Fumoto drain valve on a car that had a drain plug that pointed straight down unless it was very protected. After installing this, I thought about getting one for my F350 until I took a look at where it would sit. The oil pan isn't the lowest point (the cross member and some of the off road package skid plates being a bit lower), but it is very exposed. I don't aggressively off road or anything but I camp and hunt in some pretty off the grid places and often times ground clearance is at a premium.
Unfortunately on most cars the oil pan is already one of the lowest points.
Old 02-01-2019, 10:34 PM
Kpmikey808
Kpmikey808's Avatar
Originally Posted by PNW_IPL
Why no pics installed? Why no pics draining. Not really a review dude. Get better...
After a year - fumoto has been good - 26.25 FTG & family of 5- never hit the ground with drain plug
ngolbuff (02-04-2019)
Old 02-01-2019, 10:43 PM
Kpmikey808
Kpmikey808's Avatar
Old 02-03-2019, 07:36 PM
rotarymike
Moderator in Moderation
rotarymike's Avatar
I have a fumoto on mine and my only complaint is the time it takes to drain. Other than that, super convenient. I thought about safety wire for the valve lever but it seems to stay pretty solidly closed.
Old 02-08-2019, 07:05 PM
SonicVQ
SonicVQ's Avatar
To each his own....
for me this a $30+ solution to a problem that doesn't exist.
Over the life of the car, the oil is only changed about 25 times (assuming 6K oil changes and you keep the car for 160,000 miles)
ImportPartsPro
Engine/Intake/Exhaust
953
12-15-2019 10:10 PM
Kevdog93
General Tech Questions
23
03-21-2017 06:19 PM
Overboard
10-13-2016 10:09 PM
Quick Reply: Review Fumoto Oil Drain Valve
