Fumoto Oil Drain Valve
Installed this today - next oil change will be easy breezy -best 26$ I spent in awhile
I have been tossing around the idea of getting an oil drain valve. Would this "F103N" work on most G37's (X, sedan, coupe)? I only ask because I see a large assortment of different drain valves on the site listed for G37. I like that the one you have has the longer neck where it drains.
Plus this would mean no more buying crush washers for oil changes right!?!?!?! |
Originally Posted by ngolbuff
(Post 4179836)
Plus this would mean no more buying crush washers for oil changes right!?!?!?! Yes u won’t need crush washers anymore |
Why no pics installed? Why no pics draining. Not really a review dude. Get better...
I can see the benefit of this if you drive a lot and do oil changes often. I do an oil change once or twice a year at most. Not a big deal to r&r the drain plug.
What happens if the spring holding the lever fails? Is the effort to rotate the lever slight or significant? Here's an interesting perspective - Warning -- Oil Drain Valves (EZ-Drain & Fumoto) - Ford Powerstroke Diesel Forum IMO, KISS. |
I have one on my S2K and I change the oil quite frequently in that car. The valve makes the changes so much easier. I am concerned about possibly getting it snagged on something and breaking off, so I keep the original drain plug in the car at all times. With the G37, that should not be as much of an issue. I also used one on my 3G TL.
The other issue mentioned in the link provided by Jsolo above likely does not relate to our cars, as it seems related to a design problem already present in the specific vehicles being discussed on that forum. |
Originally Posted by PNW_IPL
(Post 4179901)
Sole sasa oi |
I installed a fumoto drain valve on my lancer a few years back. It hung below the engine crossmember which made it the lowest point to bottom out. After 2 oil changes there was dirt and debris in it and it would not stop a fast drip.
i went back to the regular drain plug. I've never changed the crush washer on it in 5 years, always torque it to spec and has never dripped. I change the crush washer on my BMW 335i everytime but only because it comes with the filter. I wouldn't recommend it but i trust the used washer more than that fumoto valve with the nylon washer that cracked way too easy. i hope you have better luck than I did. |
(Post 4179901)
Originally Posted by ethan10502
(Post 4186471)
If he just installed it, how would you get pics of it draining? And it looks like a quick drain plug on the oil pan, not a big deal. The point is it make draining oil quicker, easier and less messy than removing drain plug. Not reall;y a comment dude. Get better.
Why would you consider installing this? How's the fit and finish? How does it compare to its competitors? Does he address the pros and cons of usage? What are some other options? Can you use it with other parts you've installed? Yeah, sure. It's a easy access drain plug. Anyone with a brain knows how that works. But the point of a review is to be thorough and to provide those who are looking for one easy access to information that might not be common knowledge. Not a picture and a sentence. |
Originally Posted by bPChaos
(Post 4187053)
I think the point is - how is this a review? A stock picture, captured from a phone, and a line saying he's installed it. A review that does not make.
Enough of this non-sense. Keep it on point, that is, the Fumoto drain valve.
I have one. I love it. Changed the oil maybe twice with it. Couldn't be any cleaner or easier.
Only comment I have is the oil drains slower. The lumen is obviously a lot smaller then the threaded drain plug hole. I always drain warm anyway so that helps somewhat. Cold oil would likely suck. Regarding someone's question about how easy it turns. There is like a spring detent where you push and then twist. A casual bump wouldn't rotate it. You can also get a little plastic c-clip that straddles and locks the lever for additional security. I got one just in case. On our cars it's all covered by the lower shroud anyway so the likelihood of it getting bumped is pretty near impossible. Sorry, no pics. I've never changed the crush washer on any car of I've ever owned other than a rebuild of Toyota pickup once. Never had a leak in a conservative estimate of probably 100 oil changes across a dozen cars. Do most people really change it every time? |
Originally Posted by NW_6MT
(Post 4188180)
also, I change my washer every time, could probably get away without doing it, but i just bought like 20 of them for about 5 bucks or something a long time ago and have them handy in the garage when i change the oil |
Don't think I explained it very well. You pull off the clip (1 second) and lift and twist the lever 90 degrees (1.5 seconds). No tools, no mess, no oil on your hand as you're making that last few turns to remove the drain plug and trying to dodge the stream of hot oil. The clip: https://cimg1.ibsrv.net/gimg/www.myg...7900935eae.jpg How it fits: https://cimg6.ibsrv.net/gimg/www.myg...8f1d776e33.jpg |
