Clutch and flywheel replacement job write up wanted
The CSC on my sedan recently took a dump. Replacing with Zspeed HD CSC. While I'm in there, going to install new oem clutch kit w/ CZP 17lb steel flywheel, SS braided clutch line, new oem CMC and hose. Converting to Motul RBF600 fluid to tolerate the high heat. Doing the labor myself on a school lift, so time is of the essence. Anyone have a link to a full write-up for a clutch and flywheel replacement job? I have watched numerous youtube videos on the subject, but the more info I can grab the better. A full list of torque specs for the job would be nice to have as well. Thanks in advance.
this thread has the torque spec also
DIY: Replacing Your Clutch, Pressure Plate, Flywheel, and CSC (Zspeed HD CSC) - Nissan 370Z Forum
Best bet is to download the factory service manual. IIRC there's links on this site - Paging @ILM-NC G37S as he usually is on top of that.
The one trick to it is the FSM calls for removing the ABS booster to get to the master cyl - HOWEVER there are some howtos that show how to wiggle around that booster without removing.
I have the same setup except I went with the 20# steel flywheel.
The FSM can be found here, at least the 370z one.
https://www.nicoclub.com/nissan-service-manuals#G37
found the g37 one
https://infinitig37.com/2013-Infinit...Coupe-FSM.html
found the g37 one
Rybitron
Jan 1, 2020 04:40 PM
steez
12
Mar 8, 2016 01:45 PM
