Help Code P0011 Fix
I've owned my 2012 G37xs for about a month now and about a week ago while I was driving, my check engine light came on and car started to go into limp mode @2500rpm. Pulled over, scanned it and it read P0011. Took it back home, changed oil and filter, didn't fix. I then ordered 2 new VVT Solenoids and replaced them both. Still hasn't fixed this issue. Idk if it's the camshaft sensors, camshaft actuator/sprocket, etc.
Just need some help and ideas on what could be wrong. Was thinking about switching the cam sensors and seeing if the code changes from bank 1 to bank 2. Just need some suggestions as I'm running out of ideas.
(P.S. When I did the oil change, oil was very low and dirty, maybe only a qt came out. Guy I bought it from said he changed it in June. Tbh I should've just changed the oil when I first got the car, despite what he said.)
Here is the list of possibilities for P0011 from the FSM. Based on what you noted about the oil, you might want to look into that last one on the list.
• Crankshaft position sensor (POS)
• Camshaft position sensor (PHASE)
• Intake valve control solenoid valve
• Accumulation of debris to the signal pick-up portion of the camshaft
• Timing chain installation
• Foreign matter caught in the oil groove for intake valve timing control
@BULL It looks like this is another victim of the phaser???
You should try AC off. Should be closer to 650-700rpm.
UPDATE: So I booked an appointment with the dealer since no local mechanics could get the parts. A week before my appointment, the car wouldn’t start. For about a week I was trying to figure out what was wrong (battery, fuel, etc). Then I hooked up my OBD scanner and found a camshaft position sensor code.
Replaced the sensor now it starts and I’m no longer getting code p0011. Car is running a lot better too.
It’s amazing that a $50 part saved me from paying the dealer probably over 2 grand for sprockets, timing chains, and labor that I didn’t even need.
Glad you were able to get it fixed.
Well, There are counterfeit NGK and you can be fooled easily unless you know what to look for. Not sure on O2's. RA should have genuine. OEM vs aftermarket are NOT the same quality. How do I know? I work in the OEM supply base. Doesn't matter who or where it was made. The difference may be small but there is a difference.
I replaced my sensor with the Hitachi VTS0003 and VTS0005 from RockAuto but still have the codes. I'll be purchasing the OEM Hitachi unit base on your comment.
Oh is DEFINITELY on tires! That is where I learned the difference back in the early 90's from a Bridgestone guy in Nashville. EVERYONE has issues and that is where those go is...aftermarket. You might try the $tealer. Also I got mine of RA and it was ok. You may have other issues.
