Help Single Click/Clunking/Knocking Noise when I rev the car in Neutral
Old Jul 26, 2023 | 03:27 PM
Nissang37's Avatar
Nissang37
Hello everyone, i just found this forum and hopefully I can get some help from here. Earlier this month I got me a 08 G37s with the 6speed transmission, I love the car, the engine sounds healthy, transmission doesn’t have any grinding or any weird noise.
Last Saturday I went to the shop to do a complete maintenance, they changed oil filter, engine oil, transmission oil and diff oil.
Car runs perfectly, but yesterday coming from work, when I parked the car, I revved it and heard a click noise it sounds every time I hardly press the gas pedal (flooring it). When I rev it like with a 50/60% of gas no click can be heard.
  • All fluids are good
  • It seems it has new belts on it
  • New spark plugs were also installed by the previous owner
  • New clutch was also installed by previous owner
I believe it is coming from an upper area in the passenger side, I am not sure what it can be.
Please help, I don’t really want it to be a serious thing as i already had bad experiences with my old car (04 350Z).
PLease see the video (3 videos In 1): https://youtube.com/shorts/K8tQIwnYIxg?feature=share
Thanks.
Will.
Old Jun 4, 2024 | 06:26 PM
brettg's Avatar
brettg
Probably I am having the same issue, when I floor the pedal in Neutral, Park, or Drive. If the engine is on idle rpms, if i hardly floor the pedal, it sounds like a knock. I couldnt figure out the cause.
Old Jun 4, 2024 | 06:34 PM
Nissang37's Avatar
Nissang37
Not a problem at all?
Well, I later found out my car was tuned a few years ago so it is probably something related to that. Car is running perfectly after 3500+ miles since July last year 👌🏻
here is a video I found that shows my exact same noise.
https://youtu. be/9qL5ePtN9K8?si=vxrMlgKWKOSlpQ80 (Delete the space)
Old Jun 4, 2024 | 07:10 PM
brettg's Avatar
brettg
That is the exact same sound I am having. Have you reverted back to stock tune to solve it or retuned it again?
Swislok
Aug 24, 2019 09:59 AM
kennyG37x
General Tech Questions
Apr 9, 2018 11:10 AM
alex
Dec 31, 2011 08:07 PM
SilverTL05
Aug 25, 2009 01:08 PM
cretan
Feb 16, 2008 02:52 AM
