Help Coolant in Spark Plug Well
Old Feb 24, 2023 | 09:15 PM
jrn51's Avatar
jrn51
Originally Posted by thescreensavers
If you don't live somewhere that is cold
Unfortunately, I live in the North East, winters get harsh here.
Old Feb 24, 2023 | 09:18 PM
thescreensavers's Avatar
thescreensavers
No problem, you can go to any auto parts store and they sell coolant hose by the foot you can replace those lines which should solve your problem.
Make sure you top off the coolant
Old Apr 14, 2023 | 08:51 PM
Charzardbolt's Avatar
Charzardbolt
That happened to me when I first got my car! 2010 g37x. I found the solution. The coolant was leaking from the TB above cylinder 5. You have to fix your plastic heater core connection, forget the name it goes by. It's most likely cracked and is introducing air into your coolant system causing it to build pressure and for whatever reason it likes to leak from that place in the TB. I hope this helps! (I also used a screw ring to tighten the TB hose)
Old Apr 17, 2023 | 02:36 PM
BULL's Avatar
BULL
Moderador
Your problem is an external one from the throttle body hoses leaking onto your coils. You can see see the dry spots on the VC.
Replace the hose or the clamp or delete.
G37xMN
26
Aug 1, 2022 08:04 PM
McBoing
Jun 26, 2022 05:35 PM
carlos27
Mar 8, 2022 06:31 PM
Bryan Reyes
General Tech Questions
Feb 2, 2022 10:00 AM
Leon Engle
Feb 11, 2019 02:23 PM
