Help Transmission leak
Old Oct 13, 2022 | 03:19 PM
abz10's Avatar
abz10
Transmission leak
I’ve recently changed my entire transmission for a used one after my radiator blew and mixed coolant into my transmission and destroyed the old one. Fast forward 2-3 months. Cars been running amazing also, I noticed a leak where the transfer case meets the out of the transmission circled in the photo.
Now the part I don’t understand is that I’ve been to 3 shops and have all gotten different quotes on where it’s leaking. First guy said it’s the internal seal of the transfer case that’s gone bad. Second guy said it’s an output shaft seal which I don’t think is it. And the third guy said it’s was the back of the actual transmission (part in blue) and it’s leaking through the housing to the transfers case
NOTE: I’m not losing any fluid in my transfer case only transmission.
thanks for your time in advance
Old Oct 13, 2022 | 03:58 PM
BULL's Avatar
BULL
Moderador
The reality is that the fix can be an uncertain one.
More than likely it's coming from either the trans case to the transmission gaskets which boils down to technician
It's a heavy job that can be quoted like a full trans overhaul or a simple trans case removal and light disassembly of the transmission.
Your best bet is to clean, clean, clean this area well prior to getting quotes. It will yield the most realistic quaote.
Old Oct 13, 2022 | 05:45 PM
abz10's Avatar
abz10
yea both mechanics cleaned the surface and waited for a leak. A drop came out directly from where the red circle is
Scottfreidel
Aug 8, 2020 11:23 AM
srirachapapii
Jan 31, 2020 12:22 PM
AbeG37vq
Nov 26, 2018 01:53 AM
sugargenius
Nov 4, 2017 08:52 AM
si_driver
Oct 19, 2015 11:11 AM
