Help Fueling questions
Old Jun 26, 2022 | 09:47 PM
Wtfever's Avatar
Wtfever
Fueling questions
So I'm getting ready to replace the fuel pump in my G37 just as regular preventative maintenance thanks to the integrated filter, and I'm wondering if it's worth an upgrade to one with more lph. I'm still on factory injectors, would it make more sense to do those first? For a bit of context, mods are:
Stillen Gen3 CAI, Fast Intentions Test Pipes, Fast Intentions Catback, I have no intention of going forced induction at this stage
During my last tuning session with Uprev they did mention I could use a bit more fuel, this was awhile back as I've been happy with where I was at power wise. But if I'm gonna replace something I like to go a step above whenever possible. Complicating the issue is I can't seem to find sources that agree with each other about the different flow rates of the OEM injectors or fuel pump to do the math myself, so please feel free to chime in with any information you may have. Should I hold off on doing the pump until I can get bigger injectors too? Or will I still see a benefit to doing one, then the other?
Old Jun 29, 2022 | 02:05 AM
Birdie's Avatar
Birdie
No real benefit from doing one and then the other besides you will have it out of the way.with that being said the only thing you can upgrade is your pump itself .I personally wouldn't go over 340 lph
once the engine is warm and you try to restart it ,it may crank a bit longer than what you're used too.
You will definitely need a retune after installing bigger injectors and I highly recommend you do it at the tuner shop and not drive at all with them installed before the tune. May need a tow if they dont allow you to do it there.
If you are not getting any more upgrades its probably best to just let it be ,seems like the fuel department is adequate.But if you are this is probably the best time into looking to go e85.
Old Jul 11, 2022 | 06:56 PM
4drMonsters's Avatar
4drMonsters
First off thank you very much for your response, nice to see this place isn't dead as it's been instrumental in my research in buying the car back in 2016, as well as every mod made since. I'm trying like hell to find E85 somewhere close by, an hour drive to fill up my daily isn't ideal. I'll probably take your advice, skip the injectors for now, maybe pull them and clean them but upgrade the pump since it's due to be replaced for preventative maintenance anyways. Unfortunately there aren't any professional dyno tuners in my area for these cars, which is absolutely ludicrous to me and something I hope to change in a few years. All Honda, Subaru, BMW, or American tuners around me even though there's a healthy VQ community
AnotherVQ
38
Dec 14, 2021 09:05 PM
flipmode007
Nov 3, 2018 06:39 AM
Dan08g37s
Oct 26, 2017 03:49 PM
Upscale Speed
Jan 22, 2017 08:13 PM
Q8y_drifter
14
Jun 14, 2010 06:59 PM
