Help 5at stuck in 4th
Old Apr 26, 2021 | 09:25 PM
SquirrelSlapper's Avatar
SquirrelSlapper
5at stuck in 4th
I have an 08 g37 coupe with the 5at and literally the second it hit 150k miles it stopped shifting and threw a cel. I used a launch obd2 reader and it doesn't recognize the code being thrown. I changed the transmission fluid a little over 2 weeks ago so I don't think that's an issue. Anyone have any ideas on what it could be?
Old Apr 26, 2021 | 09:49 PM
SquirrelSlapper
I don't know if this will help or not but the AFS light came on at the same time
Old Apr 27, 2021 | 09:11 AM
ILM-NC G37S's Avatar
ILM-NC G37S
1) Will it not shift into 5th using DS/Manual Mode?
2) Did you perform the fluid change yourself or through a mechanic/shop?
If possible, you may want to take the car to have AutoZone or someone with a better scanner to check for codes (or, look into OBDFusion or Torque apps).
Right now the issue points to the TCM (Trans Ctrl Module) with AFS being a symptom, not a cause, of a "failure." Knowing what codes are being set will help narrow down what is going on.
Old Apr 27, 2021 | 09:03 PM
SquirrelSlapper
It won't up or downshift using either automatic or manual mode. I did the fluid change myself so I could've done something then, however the atf level is still good. For now I'll probably just take it to AutoZone tomorrow to get the codes checked. Ill have to check those apps out, thanks for the suggestion.
Last edited by SquirrelSlapper; Apr 27, 2021 at 09:05 PM. Reason: Better wording and cant grammer
Old Mar 23, 2025 | 08:04 PM
naterem1988's Avatar
naterem1988
did you ever find the issue? im dealing with the exact same thing.
Bbuck
Sep 18, 2019 12:40 AM
SaskG37S
Jul 8, 2019 10:24 AM
Rusty.
Oct 8, 2016 04:40 PM
Basicklee
May 6, 2013 04:37 PM
Nnn7
Jun 30, 2012 09:13 PM
