Bad Engine Noise + Overheating
Old Mar 23, 2021 | 04:45 AM
Franklin_lagos's Avatar
Franklin_lagos
H Guys,
I own a 2008 infiniti G37 coupe with 150,000 miles
A week ago whilst driving I notice that the temperature gauge had shot right up, and I could see steam coming from the engine by the windscreen.
Found out that the heater hose connector was broken. The heater hose connector has now been replaced but now coolant gushes out of the radiator and the engine makes an intermittent tractor like noise
I have attached an audio sample of this
Please can anyone tell me what this noise could mean?
Thanks!
File Type: mp3
Old Mar 24, 2021 | 04:19 PM
latino914's Avatar
latino914
Did you bleed all the air out of the system?
Old Mar 24, 2021 | 04:35 PM
Franklin_lagos
[QUOTE=latino914;4292817]Did you bleed all the air out of the system?[/QUOTE
Not sure would need to ask the machanic who changed the heater hose connector. Do you have any idea what could be causing the engine noise? Some online folks have suggested it could be broken cats
Old Mar 24, 2021 | 05:07 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by Franklin_lagos
...The heater hose connector has now been replaced but now coolant gushes out of the radiator and the engine makes an intermittent tractor like noise...
1. If coolant is "gushing" out of the radiator SHUT THE ENGINE OFF!
2. Why on earth are you revving the engine when there is little/no coolant in the system?
Why not take it back to the mechanic who did the repair? It is obvious that they did not repair it correctly.
Not trying to beat you up, but running a engine when there is no coolant in the system is a engine waiting to blow. Tow it to the mechanic- let them fix it right.
Eugenius
14
Oct 15, 2019 02:56 PM
carlos0rojas
Nov 29, 2017 10:37 PM
derekc89
Nov 2, 2012 05:40 PM
boss23
Apr 29, 2009 01:57 AM
stevenmeister
Apr 1, 2008 08:12 PM
