Help with car not starting (included videos)
Old Sep 10, 2020 | 08:09 PM
MStrike's Avatar
MStrike
Hey, I recently got a 100k '11 G37 and got the error code P0340, and just today I replaced both camshaft position sensors, where the code disappeared. However, my car was not starting and this actually began 2 days ago while I was waiting for my parts (one of the effects of faulty camshaft position sensor(s) is the engine not starting so I thought that it was responsible for it), but it still won't start. I attached a video (https://streamable.com/mggjdh) of what it shows when the car is in the 'On' position, and then the red light signal appears after for a bit (https://streamable.com/vsc1ys), which I also replaced the key for battery but it didn't do much. Finally, after trying to start it, I heard this clicking noise (starter issue?) that persisted for like 10 seconds (https://streamable.com/ru4b0b). I don't see any other codes currently. Any thoughts on this? Thanks.
Old Sep 10, 2020 | 08:53 PM
ILM-NC G37S's Avatar
ILM-NC G37S
There is a difference between the engine starting (firing up/running) and the engine turning over (cranking).
Judging from the videos, the engine is not turning over (cranking). More than likely you have a dead /dying battery. That clicking noise is the starter solenoid which "clicks" when there is not enough power to engage the starter motor.
Regardless of the cam sensors, the engine should still turn over/try to start. Check your battery and connections.
As for the blinking security light, that is normal.
Old Sep 10, 2020 | 09:05 PM
garryg1999's Avatar
garryg1999
The clicking noise is probably because you have a dead battery, I had the same problem of the clicking noise, changed my battery and my g37 started up
Old Sep 10, 2020 | 09:25 PM
MStrike's Avatar
MStrike
Oh, I see. I read online that the camshaft could result in the engine not starting, so I immediately assumed that it would be that. Nevertheless, would you recommend for me to recharge my dead battery or replace it?
Old Sep 10, 2020 | 09:27 PM
MStrike's Avatar
MStrike
Oh, ok. Any certain brands you would recommend? Also, why did you choose to replace it instead of recharging it?
Old Sep 10, 2020 | 11:44 PM
juster's Avatar
juster
See if you can read the voltage with your scan tool. Try to recharge the battery.
LuvMyG37x
General Tech Questions
Nov 15, 2020 05:12 PM
jfridge92
30
Jan 30, 2020 03:42 PM
Mhau
Jan 22, 2018 06:39 PM
Stone27
Apr 15, 2017 02:04 PM
shane7352
Mar 24, 2016 02:20 PM
