MotorvateDIY Episode Previews - Lots of good stuff!
Hey everyone, Frank from Motorvate here...
Over the last year, we have been doing a lot of research & development.
Now, I want to take a moment and give you a sneak preview of what you will see on this channel in the next few months.
Future Episodes:
Differential oil temperature & DIY gauge.
Manual transmission oil temperature & DIY gauge.
Fuel pressure at different engine loads & DIY gauge.
Engine oil pressure & temperature at different RPMs. You won't believe how high it can get!
Crankcase pressure comparison: Factory vs PCV delete. We will show which one is lower and by how much!
Inside the upper intake: We cut one open and explain its secrets.
Demo of our easy to install engine oil and automatic transmission oil temp gauge that is under development.
Inside the VHR's ECU. We take a high level look at the guts and explain what each section does.
How to copy the ECU factory tune (ROM) to an SD card in 5 minutes for about $15
Quick look at the structure of the factory tune and the start of OPEN SOURCE VHR ECU TUNING!!!
As you can see, there is a lot of amazing and unique G37/370z content that will be coming to this channel.
If you want to see these episode 2-3 weeks before they are on YouTube, please have a look at my Patreon page: https://www.patreon.com/MotorvateDIY
Thank you!
Future Episodes:
Thank you!
@MotorvateDIY Glad to see your still at it! Was worried that you disappeared off of YT. However, I do remember that you said prior to this that you had a lot going on
Nonetheless, always excited for your content!
ANMVQ
Jun 4, 2016 10:52 AM
