Ok so I'm building an intake system and wanted to use my short ram tubing that I got super cheap but I'm missing some of the parts. I was wondering does anyone know where I can get them locally? Not the actual parts persay but couldn't I piece together some things from home depot?
This is what I need
The tubing that goes to the manifold is what I need. Ahhh help is greatly appreciated!
Can you confirm this is a typhoon kit? I'm searching and I keep seeing something that screws into the intake piping but mines aren't threaded at all. Well one of them aren't. One has a tube and the other one has a hole. If it's not then that would explain why I only spent 60 bucks on em with the maf sensors attached lol
That will work. The reason why one has a tube is so the factory hose can fit well.
If you're not running catch cans I extremely suggest the Z1 breather silicone hoses.
When they say theirs will be the last breather hoses you'll buy they were not kidding.
Any suggestions about this?
Stock hose won't reach to the intake, is the little black box needed? Can I just remove it and use a vacuum t connect all the hose?
That’s the box for PCV, you probably want that one. Maybe just a slightly longer hose on the bottom of it going to valve cover? Those hoses are terrible, mine slip off the valve cover every time I pull my intake off.
