Power steering reservoir bubbling
Old Jun 27, 2020 | 12:38 PM
McGo OnezeroOne's Avatar
McGo OnezeroOne
Hey guys just wondering if anyone has noticed their power steering fluid reservoir bubbling before? i just got a g37 and noticed it was doing this. any suggestions are appreciated!
TIA!
Old Jun 28, 2020 | 04:52 AM
Birdie's Avatar
Birdie
Yes I believe this is common.i am running synthetic fluid plus a cooler. Before that I didn't have issues.
Old Jun 28, 2020 | 08:13 AM
McGo OnezeroOne
is the cooler aftermarket? Ive never heard of a power steering fluid cooler before. I was almost thinking there was a leak in the system somewhere but the fluid in my reservoir is still near the max line?
Old Jun 28, 2020 | 10:06 PM
Birdie's Avatar
Birdie
No leak it's normal. Yea my cooler is aftermarket
Old Jul 6, 2020 | 04:19 PM
dirtnapper56's Avatar
dirtnapper56
Usually bubbling indicates air in the line. Have you tried bleeding it or having it bled? Run the car with the cap off the PS reservoir and crank the wheel all the way to one side, wait like 5 seconds, crank it back ALL the way to the other side. wait 5 seconds. Do this like 5 or more times and see if it improves at all. If not, double and triple check to make sure you have no leaks anywhere in your lines or your rack (even into the dust boots by the tie rods). Your reservoir should not be bubbling
FPVJAY
Feb 12, 2018 08:46 AM
Ape Factory
Jun 21, 2016 12:04 AM
Ape Factory
Jan 30, 2016 02:37 PM
stevenmeister
Dec 16, 2009 09:00 PM
