WOT below temp safe mode?
Old Feb 5, 2020 | 10:16 AM
BULL's Avatar
BULL
Moderador
Hello there, I'm wondering if these cars have safety parameters that would turn off the engine if they're not met. Example: Some vehicles wont engage Lift/high cam unless they've reached operating them.
I was coming out of the of the back of the building and decided to lay on it while temps were half way and while it shifted to 2nd car stalled and turned off. Turned back on and let it warm up and no issues.
Leaving work I decided to replicate and surely enough it did, temps were again half-way. Don't know if anyone else has had this happen them however I found peculiar as I have not found info of it happening to others.
Let me know if this has happened to you, thank you.
Old Feb 5, 2020 | 10:22 AM
Ho there.
I live in Western NY, where below freezing temps are common, and this has never happened to me. Then again, I never go WOT unless the car is up to temp, regardless summer or winter, and TBH I'm disinclined to test it out.
Didn't you recently cut & splice sections of your wiring harness for an engine bay tuck? Could there be a connection between those events?
Old Feb 5, 2020 | 10:42 AM
BULL's Avatar
BULL
Moderador
Ho there.
Negative, that was on my V35, the V36 just moved things around.
Reason why I ask is I did dismantled the entire front timing covers to do seals and tensioners and though everything has been working fine this hiccup had me wondering if anyone else had noticed this.
Old Feb 5, 2020 | 02:45 PM
PNW_IPL's Avatar
PNW_IPL
I'm going to say no. Here's why. When I bought my 13 IPL we started it cold start. Waited 5 min and tore up back.roads before deciding to buy it.
Old Feb 5, 2020 | 07:12 PM
BULL's Avatar
BULL
Moderador
This is good to know. I'll be trying again in the next couple of days to see where it goes.
Old Feb 5, 2020 | 07:16 PM
PNW_IPL's Avatar
PNW_IPL
Download torque pro app and you'll be able to see oil temps. Check out motorvate on YouTube for steps. Definitely dont go too crazy while engine is totally cold.
Old Feb 6, 2020 | 09:15 AM
SonicVQ's Avatar
SonicVQ
I don't think so...
I have been doing some research on the VQ37 for oil pressure vs oil temp vs engine RPM.
One of the tests (which I hate doing!) is WOT to 7,500 RPM on a cold (0C / 32F) engine.
It pulls hard to redline and doesn't stall or turn off.
I suspect your throttle bodies might be dirty. When was the last time you cleaned them?
Old Feb 6, 2020 | 09:26 AM
BULL's Avatar
BULL
Moderador
Originally Posted by SonicVQ
I don't think so...
They're clean, I have done massive amount of maintenance to the car all at once. Timing covers, ALL gaskets, Manifold/throttles/MAFs cleaned, Waterpump, Galleries, tensioners. and have probably about 24 hours of driving time since. I still have not duplicated it since Tuesday as I'm waiting for additional part.
Throttles were left connected during the process and they were cleaned correctly, overall the car has not given me any issues other than this and sincerely I feel like this could be tied to something else. Just crossing Ts being that most vehicles with Variable cam components and oil temp sensors seem to have some safety precautions to prevent "granadeing"
Thanks again for the input guys.
Old Feb 6, 2020 | 11:02 AM
SonicVQ's Avatar
SonicVQ
After cleaning the MAFs, did you do the "idle air volume learning"?
Old Feb 6, 2020 | 03:14 PM
BULL's Avatar
BULL
Moderador
I did with consult. I have since re - routed my PCV system and it's working fine however I learned the stupid importance of idle relearn on these cars.
I pray for those that dont know about idle learn and try to work on these with old knowledge.
Old Feb 6, 2020 | 03:41 PM
SonicVQ's Avatar
SonicVQ
Why re-route the PCV system?
Old Feb 7, 2020 | 09:36 AM
BULL's Avatar
BULL
Moderador
Looks and also some function.
I spent a lot of time into the bay to have it look the way I wanted and the PCV system is just ugly and in the way. Aftermarket system just had hoses to everywhere and were not compact enough so I made my own.
Looks a lot better in my opinion
Old Feb 7, 2020 | 12:09 PM
SonicVQ's Avatar
SonicVQ
Looks good!
Old Mar 5, 2020 | 01:33 PM
BULL's Avatar
BULL
Moderador
This problem never happened again, I suspect it could have been due to a bad battery.
Old Mar 5, 2020 | 02:50 PM
slartibartfast's Avatar
slartibartfast
Thanks for adding the follow-up.
jhg888
17
Sep 1, 2019 11:53 AM
farmurr
Nov 15, 2013 05:08 PM
Mazaki
Mar 20, 2012 03:29 PM
MacNH
May 9, 2010 01:48 PM
mike3000
Dec 13, 2009 01:59 AM
