Squeaking noise when AC on
Old Jan 12, 2020 | 02:15 PM
Rollo's Avatar
Rollo
So when I turn my engine off and had the AC running there is a squeaking noise as something is spinning down. No noise when the AC is not on. Is this more likely a bearing/serpentine issue or an AC compressor issue?
2013 coupe with 98k miles in case that is pertinent.
thanks...
Old Jan 12, 2020 | 03:12 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Radiator/ AC Condenser fan(s). They are the only two things that would "spin down" once you shut the car off. If it was a belt/bearing issue you would only hear it while the engine was running/ AC engaged.
You can try spinning each fan (there are 2) by hand and see how smooth they turn or if there is any resistance/rumbling. However, try this ONLY when the engine is cold or if you disconnect the battery. Even with the engine turned off the fans can still come on...
FWIW, I had to replace mine about 2 years ago ('08, ≈101K miles) thanks to beach sand...
Old Jan 13, 2020 | 07:43 PM
Rollo's Avatar
Rollo
Thanks for the advice. I will try spinning those fans this weekend.
Old Jan 23, 2020 | 12:10 PM
Surfnazi's Avatar
Surfnazi
Check belt tensioner
Lamify
General Tech Questions
Jun 7, 2017 01:29 PM
Hedgehog25
The M - Spot
Nov 5, 2014 10:23 AM
bill90879
36
Mar 8, 2013 01:46 AM
SlateBlue G
Mar 2, 2012 11:38 PM
boss23
Apr 29, 2009 01:57 AM
