Noise on cold start
Old Nov 17, 2019 | 11:26 PM
Whiterocket's Avatar
Whiterocket
Noise on cold start
On every cold start something sounds like a small exhaust leak/rattle but after maybe 10 seconds it goes away. This noise has gotten louder over the past few weeks. Could this be the notorious timing chain guide problem?
Old Nov 18, 2019 | 08:25 AM
llebcire's Avatar
llebcire
I'm sure others will chime in with more knowledge.
Question - are you able to have someone else start the vehicle when cold? You mention both exhaust and timing chain - being able to be at the engine with hood open during cold start might help you pinpoint which area the noise is coming from, same from being closer to the exhaust.
-Eric
Old Nov 18, 2019 | 10:13 AM
Whiterocket
The noise is most heard from right under the driver side door. It goes away after maybe 10sec to 1min
Old Nov 18, 2019 | 06:53 PM
PNW_IPL's Avatar
PNW_IPL
NORMAL. It's the cold start procedure to get the cats up to Temp for emissions purposes. Sounds exactly like an exhaust leak.
Old Nov 18, 2019 | 07:00 PM
Whiterocket
That's good then. Thanks for the help!!
PNW_IPL's Avatar
PNW_IPL
No problem.
llebcire's Avatar
llebcire
Right - when I read this I assumed the OP had owned the vehicle for a while and this was a new noise.
It is somewhat annoying but I got used to it. I never realized it was to get the cats up to temp - great insight!
-Eric
Notfelix
Oct 8, 2019 10:26 AM
RNMcSneaks
Intake and Exhaust
Mar 29, 2018 10:16 PM
Jan 21, 2013 06:40 AM
Trader_J
32
Mar 6, 2008 03:38 PM
brd_ptty
18
Mar 2, 2008 03:51 PM
