Misfire reading with torque pro app
This is all I got.
Mode $06 report generated by Torque for Android
Vehicle VIN: JN1CV6AR5DM768234
Vehicle Manufacturer: Nissan
Vehicle Calibration ID: 13LW5A
GH1065
V3EV0A
Test report:
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.17V Min: 0V
Test result value: 0.17V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 2.55V Min: 0.7V
Test result value: 0.71V
PASS
MID:$02 TID:$80
Max: 1.19V Min: 0V
Test result value: 0.08V
PASS
MID:$02 TID:$81
Max: 2.55V Min: 0.48V
Test result value: 0.59V
PASS
MID:$02 TID:$82
Max: 3.9S Min: 0S
Test result value: 0.8S
PASS
MID:$06 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Max: 0.17V Min: 0V
PASS
MID:$06 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Test result value: 0.7V
PASS
MID:$06 TID:$80
Max: 1.19V Min: 0V
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
Max: 3.9S Min: 0S
PASS
MID:$21 TID:$80
- Catalyst Monitor Bank 1
Max: 255 Min: 10
Test result value: 25
PASS
MID:$21 TID:$82
Test incomplete or dependant test failed
MID:$22 TID:$80
- Catalyst Monitor Bank 2
Max: 255 Min: 10
Test result value: 23
PASS
MID:$22 TID:$82
MID:$35 TID:$80
Max: 13° Min: -13°
Test result value: 3.5°
PASS
MID:$35 TID:$82
Max: 13° Min: -13°
Test result value: 0°
PASS
MID:$35 TID:$84
Max: 499ms Min: 0ms
Test result value: 108ms
PASS
MID:$35 TID:$85
Max: 10,779ms Min: 0ms
Test result value: 50ms
PASS
MID:$36 TID:$80
Max: 13° Min: -13°
Test result value: 2°
PASS
MID:$36 TID:$82
Max: 13° Min: -13°
Test result value: 0.5°
PASS
MID:$36 TID:$84
Max: 499ms Min: 0ms
Test result value: 129ms
PASS
MID:$36 TID:$85
Max: 2,379ms Min: 0ms
Test result value: 10ms
PASS
MID:$3c TID:$81
- EVAP Monitor (0.040")
Max: 32.767kPa Min: 0.43kPa
Test result value: 0.457kPa
PASS
MID:$3c TID:$82
Max: 32.767kPa Min: 0.1kPa
Test result value: 32.767kPa
PASS
MID:$3d TID:$83
- EVAP Monitor (0.020")
Max: 655.34998V Min: 0.02V
Test result value: 0.04V
PASS
MID:$41 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 4.779V Min: 0.39V
Test result value: 1.155V
PASS
MID:$42 TID:$80
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 4.71V Min: 0.24V
Test result value: 1.56V
PASS
MID:$45 TID:$81
- O2 Heater Monitor Bank 2 - Sensor 1
Test result value: 1.175V
PASS
MID:$46 TID:$80
- O2 Heater Monitor Bank 2 - Sensor 2
Test result value: 1.44V
PASS
MID:$81 TID:$80
- Fuel System Monitor Bank 1
Max: 130.98999% Min: 77.00999%
Test result value: 104.29%
PASS
MID:$81 TID:$81
MID:$82 TID:$80
- Fuel System Monitor Bank 2
Test result value: 109.14%
PASS
MID:$82 TID:$81
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Test result value: 1Count
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
Test result value: 32Count
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
End of report.
Sent from my T-Mobile 4G LTE Device
GH1065
V3EV0A
Test report:
MID:$02 TID:$07
Max: 0.17V Min: 0V
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$80
Max: 1.19V Min: 0V
PASS
MID:$02 TID:$81
PASS
MID:$02 TID:$82
Max: 3.9S Min: 0S
PASS
MID:$06 TID:$07
Max: 0.17V Min: 0V
PASS
MID:$06 TID:$08
PASS
MID:$06 TID:$80
Max: 1.19V Min: 0V
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
Max: 3.9S Min: 0S
PASS
MID:$21 TID:$80
Max: 255 Min: 10
PASS
MID:$21 TID:$82
MID:$22 TID:$80
Max: 255 Min: 10
PASS
MID:$22 TID:$82
MID:$35 TID:$80
Max: 13° Min: -13°
PASS
MID:$35 TID:$82
Max: 13° Min: -13°
PASS
MID:$35 TID:$84
Max: 499ms Min: 0ms
PASS
MID:$35 TID:$85
PASS
MID:$36 TID:$80
Max: 13° Min: -13°
PASS
MID:$36 TID:$82
Max: 13° Min: -13°
PASS
MID:$36 TID:$84
Max: 499ms Min: 0ms
PASS
MID:$36 TID:$85
PASS
MID:$3c TID:$81
PASS
MID:$3c TID:$82
PASS
MID:$3d TID:$83
PASS
MID:$41 TID:$81
PASS
MID:$42 TID:$80
PASS
MID:$45 TID:$81
PASS
MID:$46 TID:$80
PASS
MID:$81 TID:$80
PASS
MID:$81 TID:$81
MID:$82 TID:$80
PASS
MID:$82 TID:$81
MID:$a2 TID:$0b
PASS
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0b
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0b
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0b
PASS
MID:$a5 TID:$0c
PASS
MID:$a6 TID:$0b
PASS
MID:$a6 TID:$0c
PASS
MID:$a7 TID:$0b
PASS
MID:$a7 TID:$0c
PASS
End of report.
That was helpful.
It shows the long term fuel trims for bank 1 are around 4% rich and bank 2 is 9% rich.
This report doesn't show the short term fuel trim, so we don't know the "total fuel trim"
(Total fuel trim = short term + long term)
In your case the ECM is adding at least 9% more fuel to bank 2. - This is on the high side of normal.
Scan for codes again, you should have a "pending" or "permanent" code still in memory - if you do, please post it.
To view the "freeze frame" in Torque:
• Touch Fault Codes
• Touch "menu / 3 dots" in the top right
• Select Freeze Frame
• Post it here for review
• Touch Fault Codes
That was helpful.
• Touch Fault Codes
• Touch Fault Codes
As for the codes and freeze frame, thanks for trying
Use OBDFusion and run a diagnostic report. This will capture everything and organize it into a logical report.
Feel free to share it with me via PM or post it here.
Here is a short video on how to run the diagnostic report:
https://youtu.be/ewNJDpWCKe4
I would like to have a look at the full report. If you are willing, touch the menu (...) and email it to yourself.
Then you can open the email and copy paste it here, or send it to me via private message.
What problem are you trying to fix?
In your first post, you mentioned that "the car went into limp mode due to a misfire"
• What was the symptom the made you think the car was in limp mode?
• Why do you think a misfire caused limp mode.
• Do you know what spark plugs were put in? (factory recommend plug is good for 105,000 miles)
I used factory sparks n when the car went into limp mode she wouldn't go over like 3k rpm n if I tried to give it power the car would start to jerk hard. So I'm trying to figure out if my car is still misfiring per the torque app. Or if I'm reading **** wrong.
Thank you for this!
The total amount of fuel correction (also known as fuel trim) is the short term + the long term.
In your case bank 1 equals: 9.38+3.12 = 12.50%
and bank 2 is: 7.81 + 5.47 = 13.28%
This tells us your ECM is adding 12-13% extra fuel to achieve the proper fuel ratio of about 14.7 pounds of air for every pound of fuel at idle.
From what I have seen on the G37 / 370z (or the VQ37VHR) this is a little more fuel correction than I would expect.
Generally a total fuel trim of -10% to +10% is considered good and -15% to +15% is acceptable by Nissan.
The good new is that your car's fuel trim seems to be in the "ok" range.
I suggest you keep driving the car, and if it goes into limp mode or a CEL comes on, run and save the diagnostic report.
Then you can compare this one (which is good) to that one.
Thank you for this!
2 questions. 1st, would the OBDIIfusion diagnostic report show any misfires n if so did you see any and 2nd, why does the torque test results show misfires. The whole reason for this thread was to try n figure out why the torque app is reporting misfire. Thanks.
You are welcome
It's important to keep in mind the fuel trim shown in the diagnostic report are a "snapshot" from when the report was created, in this case at a fully warmed up idle.
When the engine is under a higher load, like on the highway, the fuel trims will be different.
If you want to see what they are during cruise/steady state highway driving, you can use OBDFusion to data log the long and short fuel trims (for both banks), view them in the live graphing mode, or even run the diagnostic report while on the highway. (I have done it many time without any issues - even though the app has a warning)
As I see it, the fuel trims are in the OK range. Can the non-factory intake change the fuel trims? Yes, as the way the air flows around the MAF will be different. Is this bad? Nope! Your fuel trims are in the OK range.
Getting back to the misfires... Both OBDFusion and Torque show the same data from the ECM, but with different names.
OBDFusion uses Mode $06 and Torque uses "Test Results"
Cylinder #1 had 1 misfire, cylinder #3 had 2, cylinder #5 had 2.
These are VERY low counts and nothing to worry about.
When they get up to 65,535 counts, then a check engine light will be tuned on.
So.... relax and drive the car. You now have a saved copy of the diagnostic report which can be helpful for troubleshooting down the road as you have a good point of reference.
If you want to learn more about the different engine sensors (PIDs), here is an excellent video that describes them for our exact engine:
