‘08 coupe Z1 triple play (clutch, flywheel & CSC delete) input
Old Oct 17, 2019 | 01:03 AM
millertimedude's Avatar
millertimedude
Disclaimer, I did a search. Couldn’t find this topic. Thanks in advance.
Parts installed:
Z1 stage 1 (full face), medium flywheel & CSC delete
Issue:
I got the above, installed and have been driving for a couple days now. Couple questions for those who ran this setup....
Good lord, coming from a semi worn stock clutch, this is way different. Specifically, the length of travel, from the time you initially press the clutch in to the bottom, is nearly half. Is this standard/normal? It throws me off, not in a bad way but such a dramatic change from a stock to stage 1.
Can the above be adjusted? I’ve heard a RJM clutch pedal may help.
What I’m looking for honestly, is one of two things. Either tell me it’s normal and get used to it buttercup. Or yes, you can adjust the length of travel to engage the clutch. I am comfortable with the actual pressure, it’s just the very short “window” that the clutch has now id like to adjust.
Old Oct 18, 2019 | 01:38 AM
jpowersjr2's Avatar
jpowersjr2
I am not sure if you can adjust it.
Get the full RJM package, whatever is the latest and best one. I have the v3 model and love it. Didn't install it but Infiniti said it was a pain to do. It is adjustable with where the clutch engages.
Gavin17
Sep 20, 2018 08:08 AM
slotterjordan
Jun 12, 2017 10:55 AM
Z97
Mar 20, 2017 02:18 PM
michael138
Aug 30, 2016 11:58 AM
Crewnecks
Nov 9, 2014 03:25 PM
