Help Clutch Groaning When Cold: Bad Throw-Out Bearing or Old Transmission Fluid?
Old Sep 22, 2019 | 12:50 PM
hoyshnin's Avatar
hoyshnin
Here's a video where you can hear the sound while I push in the clutch pedal and let it out several times:
When the engine is cold I hear this sound, but after warming up it disappears. There are no other symptoms and the transmission works great. Is my throw-out bearing going bad? Could it be old transmission fluid? It's a 2013 IPL with 92k miles and I don't know if the transmission fluid has ever been changed (although I did recently change the clutch fluid which made no difference).
I would love to solve the problem by simply changing the transmission fluid, but maybe I just need to bite the bullet and replace the transmission components including the throw-out bearing.
Old Sep 25, 2019 | 09:08 AM
Surfnazi's Avatar
Surfnazi
Throw out bearing going out makes your trans sound like a cement mixer when clutch is not pushed in. Trans fluid should be changed every 50k miles
bythabay
21
Aug 21, 2018 08:59 PM
mobiesto
General Tech Questions
Feb 9, 2016 03:26 PM
FromZeroToKing
Jul 29, 2013 10:14 PM
Bktin
Sep 26, 2012 04:58 PM
Falker11
Jul 12, 2012 01:23 PM
