Help Installed Takeda CAI and it comes off
Old Sep 15, 2019 | 01:06 PM
JobbyKobe's Avatar
JobbyKobe
I’ve purchased and installed a new takeda cai and had it installed about 2 months ago. Whenever I give her some juice I find that my coupler comes loose from the drivers side plenum and the intake pipe comes loose which puts me into limp mode until I reconnect it. Does anyone else have this problem and any possible fixes I don’t want to go crazy tight on the hose clamp and warp the pipe.
Old Sep 15, 2019 | 02:10 PM
Surfnazi's Avatar
Surfnazi
But new screw clamp from autostore for 2 bucks
Old Sep 15, 2019 | 08:35 PM
PNW_IPL's Avatar
PNW_IPL
The polished piping is too smooth to clamp. Mine came apart at filters. My solution 1000 grit sandpaper where coupler slides in so it can bite. Sucks but if I kept tighten the clamps I would crush the piping.
Old Sep 17, 2019 | 01:04 PM
Surfnazi's Avatar
Surfnazi
Or rough up inside of filter where it slips on
Old May 5, 2021 | 05:28 PM
infiniticarplug's Avatar
infiniticarplug
I have the same issue going on with me currently right now. I hadn't had any issues with it the first 3 months of having the CAI installed(takeda). The last 2 months I installed the afe throttle body spacers and had no issue after that everything was still good clamps never came loose. I put on the swift springs and less than 2 weeks later I threw codes from the intake falling off the throttle body. Last night I noticed after retightening that it was already coming loose. Today I went and bought new clamps I think maybe the old ones weren't holding the Intske as well anymore because of the one and off with the 2 other installs. Did you ever rough up the piping to see if that helped, bc that's my next option or bigger couplers that I can put more clamps on. Never had this happen before to me.
Old May 7, 2021 | 10:43 AM
EMPIR37's Avatar
EMPIR37
Hair spray on the coupler, then slip it on when it's wet, then clamp.
Old May 7, 2021 | 09:49 PM
infiniticarplug
The new clamps ended up solving the problem so far, but if ends up happening again. Then I am going to give the hairspray a shot just so it has some sort of grip like you said. I really think the clamps were shot though. Only time will tell. Seriously though thank you for the feedback.
Old May 18, 2021 | 10:32 AM
rotarymike's Avatar
rotarymike
Moderator in Moderation
Find an exhaust shop or body shop with a bead roller and have them put a small bead edge on where it goes into the hosing. Then the clamp doesn't have to exert quite as much force to keep it seated.
Or, https://www.northerntool.com/shop/to...E&gclsrc=aw.ds
wolfxrider
Intake and Exhaust
May 27, 2017 03:47 PM
alxmlr789
May 24, 2015 11:00 PM
