Need Help - Low Pressure indication light came on
Old Jul 10, 2019 | 02:18 PM
mdanish4's Avatar
mdanish4
Hello all, I have a 2013 G37 Sedan with about 88k miles. Never had any problems and always had up to date maintenance. Last night, i started the car and started driving, a little while and boom the oil light came on. Since my car is 2013 I am not suspecting the timing cover gasket issue. I have placed the order for oil pressure sensor. Has any one have had this problem? Car is not in limp mode, neither heating up nor loosing any oil.
Old Jul 10, 2019 | 02:23 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Oil level? Any error codes?
What prompted you to just order a pressure sensor without knowing what the issue may, or may not, be?
Old Jul 10, 2019 | 02:26 PM
mdanish4's Avatar
mdanish4
oil lever is 100%. no error codes just the oil light.
I called a stealership near me and spoke to one of the adviser, he told me it could be the pressure sensor. Sensor was only $18 dollar so I decided to order and replace it to see if the problem goes away.
Old Jul 10, 2019 | 02:47 PM
ILM-NC G37S
Best advice I can give: I would limit the use of the car until you swap out the switch and go from there. If the light stays on get a pressure test done. The "sensor" is a simple switch that closes when pressure drops below a certain set point thereby triggering the idiot light.
Good luck....
Old Jul 10, 2019 | 05:11 PM
Baadnewsburr's Avatar
Baadnewsburr
I never got the light because I replaced it before ever turning on the car, but I did break my oil pressure sensor once while working on the car..given its placement (at least on the AWD G) I was surprised at how fragile and exposed it was... I basically I bumped it with a ratchet t and it broke off in its fitting...its basically made of thin brittle plastic...mind you it did last for over a decade in harsh condition up to until then so I can't say it didn't last....either way, I would imagine that it was about to snap off and would probably have given the same symptom you got now.
Hopefully thats all it its for you too, especially given the complete lack of other symptoms.
Old Jul 10, 2019 | 06:38 PM
stealthee's Avatar
stealthee
Not on a G, but my Grand Pix I used to have had a oil sensor randomly fail. I was driving along, got on the throttle for a sec, and all of a sudden the light popped. I threw the car into neutral and listened and there was no knocking or any bad noises so I babied it the rest of the 2 miles home. Inspected things, and only thing I came up with is the sensor failed. I replaced it and problem went away.
I noticed when I pulled the old one out that oil actually came out of the plug itself and after further research found that is how most of them failed.
Old Jul 10, 2019 | 09:31 PM
mdanish4's Avatar
mdanish4
I am totally lost. I got the sensor. Jacked the car up. Disconnected the harness, placed the socket on top of the sensor, started turning and all of a sudden boom! Sensor fell along with thrse two pieces. For 10 minutes i did not know what just happend. I have no clue and i dont know what to say or do i am totally in denial. How this could happen?
Old Jul 11, 2019 | 01:54 AM
jpowersjr2's Avatar
jpowersjr2
The old one or new?
Old Jul 11, 2019 | 08:59 AM
mdanish4's Avatar
mdanish4
Originally Posted by jpowersjr2
The old one or new?
When i was removing the old sensor.. The pieces in pictures above are from the oil filter bracket assembly which now has to be changed because oil is leaking from where yhe sensor is supposed to go.
Old Jul 11, 2019 | 10:13 AM
OldG2NewG's Avatar
OldG2NewG
Maybe you smacked the housing along with the sensor with the ratchet?
Old Jul 11, 2019 | 10:18 AM
mdanish4's Avatar
mdanish4
Nah.. Just tried to remove it with 27mm socket and l angle ratchet.
Old Jul 11, 2019 | 11:09 AM
mdanish4's Avatar
mdanish4
My car is 2WD and apparently there are no oil filter housing. Pressure switch goes to the lower block. I dont know what to do.
Old Jul 11, 2019 | 11:24 AM
Baadnewsburr
are you sure it goes to the block?..I would think it goes to the upper oil pan...
Either way you can get somone to weld the fitting back but if its the upper pan, you can replace the pan...probably get a used one pretty cheap from a junkyard/ebay...it may require some disassembly
xxg00w0
Jul 15, 2013 12:31 PM
BigJay
May 30, 2010 07:21 PM
kappa88af
Dec 1, 2007 02:55 PM
F1BY1
Sep 24, 2007 08:54 PM
