my tire pressure warning light came on
Old Jul 7, 2013 | 10:14 PM
xxg00w0's Avatar
xxg00w0
my tire pressure warning light came on after filling the tires... anyone experience it before? what should i do?
Old Jul 7, 2013 | 10:40 PM
BLAIR'N G372012's Avatar
BLAIR'N G372012
Reset it... its in the Screen...sounds like you went over or running under the Spec... easy fix though... look in the owners manual it will guide you how to reset it... fast its like 2-3 min
Old Jul 8, 2013 | 12:13 AM
quakerroatmeal's Avatar
quakerroatmeal
Your TPMS (!) light came on, or the Tire Maintenance light came on? If it's the TPMS (!) light...re-check your tires. What are you airing it up to? If it's the Tire Maintenance light than you can reset it on the mid display control.
Old Jul 8, 2013 | 01:38 PM
BLAIR'N G372012
Thanks quaker I didnt think on that one... if its the Tire reset then its time to rotate...lol yeah right... staggers cant... but you can flip the tires... if their made that way...
Tpms can be reset as well had to reset mine when the new wheels went on... still a simple process
Old Jul 8, 2013 | 02:49 PM
Chekov's Avatar
Chekov
Senior Citizen
On my ’08 the manual says you have to go at least 16mph to extinguish the TPMS light after re-inflating the tires to the proper pressure.
Old Jul 15, 2013 | 12:11 PM
monytx's Avatar
monytx
This is true, and I believe it's supposed to be aired up to 35 psi - I could be wrong.
Old Jul 15, 2013 | 12:31 PM
Chekov's Avatar
Chekov
Senior Citizen
It depends. The placard on my Journey says 33psi. I believe 35psi is for the sports models.
SS2006
Aug 27, 2024 07:33 PM
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
the dreame
Apr 9, 2017 10:30 AM
Sway_NV
22
Aug 29, 2015 04:58 PM
slotterjordan
Aug 10, 2015 12:17 AM
