2013 g37x click no start
Old Jun 4, 2019 | 07:28 AM
Hotsauce55's Avatar
Hotsauce55
Replaced keyfob battery and car battery
just clicks
starter fuse looks fine
whats the route or procedure from this point?
i figure measuring voltage at the starter is next but have no idea where that is on these cars?
Old Jun 4, 2019 | 11:54 AM
teahead's Avatar
teahead
You have an automatic?
Try starting in N.
Stickshift? If so, anything unplugged on your clutch pedal?
Old Jun 4, 2019 | 11:56 AM
Hotsauce55's Avatar
Hotsauce55
Automatic, tried starting in neutral no dice. Also moved the car a few feet & no success.
Old Jun 4, 2019 | 11:59 AM
Hotsauce55's Avatar
Hotsauce55
There was a tiny bit of water in the battery tray which was surprising. Hope this car was meant to be washed & hoping ecu didn't get damaged? Off to the dealer I suppose
Old Jun 4, 2019 | 12:38 PM
teahead's Avatar
teahead
stick your keyfob in the hole?
Old Jun 4, 2019 | 01:48 PM
Hotsauce55's Avatar
Hotsauce55
Yes that too
Old Jun 4, 2019 | 02:58 PM
Hotsauce55's Avatar
Hotsauce55
Damned thing was supposed to be more reliable than my Benz! Lol
Old Jun 4, 2019 | 04:36 PM
Hotsauce55's Avatar
Hotsauce55
Dealer says its the starter, arching inside
$900 installed after taxes
On rockauto I see a TYC starter for like $72 - any experience with those? Dealer wants $450 for theirs
Old Jun 4, 2019 | 04:44 PM
teahead's Avatar
teahead
That's about right.
https://www.infinitipartsdeal.com/pa...300-ey00d.html
You plan on installing this yourself? If so, and it's fairly easy to do, then go for the rockauto.
If you are not, then you'll want OEM. Labor is $$$ so you can't afford to have someone else install over and over a POS reman unit from rockauto.
Old Jun 4, 2019 | 04:47 PM
teahead's Avatar
teahead
https://www.ebay.com/itm/Genuine-Mot...temCondition=3
If it's a royal PITA to install, then buy OEM. Whether it's your or someone else installing it, you don't want to do this again and again.
Old Jun 4, 2019 | 06:17 PM
Hotsauce55's Avatar
Hotsauce55
That cheap unit I referenced is the only new one RA sells but must have some drawback. I don’t have time for the install so it’s either a buddy or the dealer. Hoping buddy can handle it. I have read a few posts about this being a more involved job. Also not convinced OEM is the best considering I only have 40k miles
Old Jun 4, 2019 | 06:40 PM
teahead's Avatar
teahead
Looks easy to install:
So, you COULD try a cheap reman unit. Up to you!
Old Jun 4, 2019 | 08:02 PM
Hotsauce55's Avatar
Hotsauce55
That car looks like RWD, assuming AWD has much less room?
Old Jun 5, 2019 | 07:58 PM
Hotsauce55's Avatar
Hotsauce55
Got the car back, starter replaced works well
interesting on the labour hours
nissan quoted me 4 to be safe took them 3 apparently
infiniti (not close to me) quoted 1.5 hrs maybe 2
indy quoted 1.3
SonicVQ
19
Apr 29, 2023 07:56 AM
SilverTL05
Aug 25, 2009 01:08 PM
