Infiniti G37 - rattle at idle
Old 01-12-2020, 12:46 AM
Kpmikey808
Kpmikey808's Avatar
Originally Posted by llebcire
It's amazing how bad (i.e. expensive) this rattle sounds and how easy it is to resolve.
-Eric
yes sir it started annoying the crap at me - every light or stop sign & one day it would rattle & the next day wouldn’t
llebcire (01-12-2020)
Old 02-23-2020, 09:29 AM
ZzBloopzZ
ZzBloopzZ's Avatar
Originally Posted by Conboss
My heat shields were rattling pretty bad, tied em up and it solved my issue. I still get a rough idle sometimes, at about 600rpm my car goes rough. It sounds like the passenger cat shield might be loose, or the shields wrapping the exhaust? Give those a shot and see what happens. (I have a hole in my exhaust, so I can’t quite hear everything perfect in my car)
What did you use to tie up the heatshield? I get such annoying rattling at idle sometimes, other times nothing. Def coming from under the car. Plan to fix it next time I do an oil change.
Thanks!
Old 02-24-2020, 09:42 AM
Hunter Dietzman
Hunter Dietzman's Avatar
Check my thread, is it similar to this? Because mine is definitely not heat shields lol.
https://www.myg37.com/forums/engine-...tle-shake.html
Old 08-31-2020, 12:18 PM
Judith Pfeiffer
Judith Pfeiffer's Avatar
Thanks for the info. Cheap clip match up at auto parts store and a 2-year rattle fixed. Another vote for the windshield washer tank clip
Old 08-31-2020, 03:50 PM
BULL
Moderador
BULL's Avatar
I chose a more "permanent" fix
socketz67 (05-18-2023)
Old 09-21-2020, 10:30 AM
NYSBASIC
NYSBASIC's Avatar
I had that same rattling sound thinking that it can possibly be the heat shield but it ended up being the windshield washer reservoir with a broken plastic clip.
Old 05-17-2023, 05:34 PM
simontx
simontx's Avatar
Talking
You guys rock.. I had the rattle noise going on for quite some time in my 2008 G35. The windshield washed bottle retaining clip was the issue!!!
Old 05-18-2023, 11:51 AM
socketz67
socketz67's Avatar
I checked mine and it was really loose, replaced with a bumper push fastener as shown in your pic and it's snug now (see pic with PN below). Over the years, I have replaced so many of these clips under the hood and fender wells, which keeps vibration related rattles to a minimum. We could almost start a thread on the topic. I also use MD weather seal on alot of potential rattles (where high temps are not a concern, like the fuse/power line for my sub amp - see below) and to reseal things like the air boxes:
Additional question, the black cover that hides the battery has clips on the ends to hold in in place, but the center portion is plastic sitting on top of metal. Would that be a source of vibration related rattles?
cody76
General Tech Questions
38
04-06-2020 06:30 PM
Carboy37
04-13-2018 09:40 AM
bill90879
36
03-08-2013 01:46 AM
deep007
02-07-2013 11:25 PM
Chris11LE
07-14-2011 09:35 PM
Quick Reply: Infiniti G37 - rattle at idle
