Transmission fluid change
Old Apr 2, 2019 | 09:23 PM
photopro's Avatar
photopro
who do you guys and ladies trust for transmission fluid change transfer case, etc.
09x sedan, 106k, runs great gonna keep it for a little while longer. thanks
Old Apr 2, 2019 | 11:24 PM
04G35NYC's Avatar
04G35NYC
With such high miles, don't touch it. Keep driving it and enjoy it
Old Apr 3, 2019 | 03:46 AM
Said Amir's Avatar
Said Amir
Transfer case, and the front and rear differential is really easy to change if you want to do it. Also if you do get the transmission fluid changed make sure they do a drain and fill, and not a flush. Because if they flush it, it will mess up the transmission by pushing gunk into other places that it does not belong. But then again it is best if you drain and fill the transmission fluid also since you will not be able to get all of the fluid out all at once, but having to drive it get the fluid to circulate, and drain and fill it 2 more times. Their is videos online, and on the forum about doing these fluid changes.
Old Apr 6, 2019 | 02:45 PM
Evorus5's Avatar
Evorus5
Adding on to this..
My transmission was swapped out by Infiniti in November with a brand new 6mt. I was talking to another g owner and he suggested I switch over to Redline fluid. Should I have a shop flush the old fluids or should I just drain and fill?
The transmission has about 4k miles.
Old Apr 8, 2019 | 12:12 AM
Said Amir's Avatar
Said Amir
The safe bet is drain and fill. Also since you have a 6mt that is much much easier to do, since you already have a drain and fill bolt, unlike the 7at it is a much different process filling it back up with fluid.
Old Apr 9, 2019 | 08:59 PM
Conboss's Avatar
Conboss
I got my local speedy to do the job. Fairly sure they did a drain and fill, and the trans was much snappier (7AT) I did notice that shifts were starting to get harder, but I don't care. If it's bad, someone know what to do about it? I can't spend another $200 for the job
Old Apr 11, 2019 | 03:49 PM
Said Amir's Avatar
Said Amir
the hard shifts is normal for the most part but Infiniti has a software update for the 7at to make it shift smoother many people on the forum had it done, and some loved it and some said it went back to shifting hard. You can also get your car tuned and they can tweak the transmission a bit also to make it smoother. I had a 2011, and a 2013 g37 coupe and the 2011 shifts a bit harsher than the 2013 but it’s nothing to noticeably unless you pay attention to it.
Old Apr 11, 2019 | 03:51 PM
Conboss's Avatar
Conboss
I drive an 09, but I also drive pretty much exclusively in manual shift mode. Never liked the programming on this transmission, and it's just more fun
Old Apr 22, 2019 | 02:20 AM
mummy2's Avatar
mummy2
As far as the trans exchange, I would have the dealer do it. They are only going to be a little bit more expensive than a side shop. I had mine flushed at 70 thousand miles at a side shop for $250 vs. $275 at the Nissan dealer. I'm super cheap. It shifted so much smoother and it stopped banging into gears. Just tell them to just exchange the fluid without using any cleaners. I had 2 software updates done around the same time. That helped too. The only downside is that to help smoothing out the transmission they made the car less aggressive than before. It doesn't rev as freely.
imatt86
General Tech Questions
46
Jun 16, 2019 01:26 PM
Walks
13
Mar 9, 2017 02:27 AM
ryang37x
Sep 22, 2015 05:33 AM
tifosi
Apr 10, 2013 04:25 PM
berny32
Oct 26, 2011 03:36 PM
