Transfer case snapped where driveshaft meets. Need advice please
Old Feb 19, 2019 | 10:13 PM
  #31
Dan G37's Avatar
Dan G37
I've got a question if anyone can help me. Are the AWD X model G37's front differential Open or LSD?
Old Feb 19, 2019 | 10:15 PM
  #32
GdaddyNY's Avatar
GdaddyNY
Open. Not lsd in front diff
Old Feb 19, 2019 | 10:16 PM
  #33
Selym's Avatar
Selym
Open. Rear differential is open, too.
Old Feb 19, 2019 | 10:18 PM
  #34
Dan G37's Avatar
Dan G37
Thank you!
Old Mar 23, 2019 | 12:08 AM
  #35
Dan G37's Avatar
Dan G37
A quick update on the differential replacement!
Me and my friend weren't able to do it in the garage we weren't able to pop out the axle and just didn't have enough wiggle room to get a comfortable position. I took it to the shop and even they said it was a pain in the ***.
They said they had to drop the subframe about a foot and disconnect alot of things in order to get the differential out.
Now its all done and the G drives great! Some pics of the differenti
al.
Old Mar 23, 2019 | 12:19 PM
  #36
Selym's Avatar
Selym
Thanks for following up!
You should consider changing the thread title to "Front Differential Case Snapped..." for the benefit of future searchers.
Old Mar 23, 2019 | 01:03 PM
  #37
Dan G37's Avatar
Dan G37
Good point thank you!
Old Mar 23, 2019 | 10:52 PM
  #38
GdaddyNY's Avatar
GdaddyNY
I didn’t realize they had to drop the subframe that much. That looks like a good opportunity to replace or upgrade your motor mounts while your in there. Thanks for the follow up pictures and glad you got your car back on the road.
Old Mar 28, 2019 | 08:01 PM
  #39
Dan G37's Avatar
Dan G37
Another update on the front differential. So they took apart the differential and found what could have been the problem.
The yellow line indicates the pin that broke somehow, causing the red line (pin) to move freely so when I hit the pothole, the red pin hit the spline of the gear and caused the front differential to crack.
The cause was most likely not changing my gear fluid and ripping on the car. Be sure to change your gear oil!
drizzy315
Feb 7, 2019 08:26 AM
sunshineskyler
Mar 9, 2017 12:48 PM
Ali6767
20
Aug 6, 2015 09:38 AM
spect2k
General Tech Questions
Jun 19, 2011 02:04 PM
