Help With Confirming the Coolant Lea
The leak is occurring above the oil pan on the driver's side. From what I found on the forum, it might be the water pump. There seems to be some sort of gasket material poking out from the area if that helps with diagnosing the issue.
The car is a 2012 6mt sedan with 60k miles.
The first image is around the general area looking from the driver's side wheel to the passenger side wheel. The second image is where I believe it's leaking from.
I've looked everywhere in the engine bay around that area and have not found anything. The car at idle doesn't seem to leak as much. A little rev made it start leaking again.
Small Update:
I check in the engine bay again around the affected area. Did not find any trace of coolant in the engine bay and anywhere higher than where the picture was taken under the car. No dry coolant on any lines or on the engine.
kyle@stillen
499
Sep 23, 2016 10:46 AM
