(kinda) new owner- constant clicking in the rear
Old 04-17-2018, 12:26 PM
therestheG
therestheG's Avatar
Unhappy (kinda) new owner- constant clicking in the rear
I've had this problem when I first got my 2013 G37 a few months back. There would be a non-stop clicking noise coming from the rear after I drive for a while and slow down/stop. The noise would disappear once I reach a certain speed and then come back when i slow down/stop.
I did my research in various online forums and everyone pointed to the same problem: rear axles needed some Molykote grease. So I did just that - brought it to a Nissan mechanic who said he was familiar with the problem and a little grease would fix it. It worked well, at least for the first week or two, as I did not hear the annoying clicking noise. But soon after, the clicking noise came back.
Is this a sign of a more serious problem? Should I go to another mechanic and have them apply grease (again)? Or is it something else?
Appreciate the help yall!
Old 04-17-2018, 02:25 PM
slartibartfast
slartibartfast's Avatar
Welcome to the site. I moved your post to the appropriate forum so others can see and help.
Old 04-17-2018, 02:44 PM
Entcee
Entcee's Avatar
If I remember right, the fix is not only grease, but the driveshaft should be rotated 180 degrees as well. Do you know if that was done?
*edit* I did remember right, here is the procedure. http://www.infinitig37.com/TSB/1SB3.pdf
Old 04-17-2018, 06:26 PM
Surfnazi
Surfnazi's Avatar
Check swaybar endlinks. If the boot is torn the grease all came out which causes clicking noises when you drive over bumps
08STLX
11-11-2016 03:46 PM
Black Bird
04-05-2010 01:57 AM
MaxToTheG37
07-24-2008 07:56 PM
Motor25
Intake and Exhaust
40
05-09-2008 05:54 PM
Quick Reply: (kinda) new owner- constant clicking in the rear
