Belt squeeling noise on cold start
Old Apr 20, 2018 | 10:50 PM
  #31
jpowersjr2's Avatar
jpowersjr2
FYI this belt has been great so far, Bando 7PK2020A.
I replaced mine at 115K miles, I had a little noise at start up and it is now gone. My tensioner indicator lined up perfect with the new belt. On a side note my tensioner was a 1/2 drive and not 3/8 drive like I originally thought.
Old Apr 21, 2018 | 12:10 AM
  #32
Dan G37's Avatar
Dan G37
Originally Posted by Entcee
41 ft lbs for the tensioner and 21 ft lbs for the idlers. I could not get a torque wrench on the tensioner bolt (and maybe the idlers as well) so I gauged by force it took to remove them.
Thank you very much!
Old Apr 21, 2018 | 12:11 AM
  #33
Dan G37's Avatar
Dan G37
Haven't seen that one! I was thinking of trying the new Gates RPM belt. Looks very promising. GATES K070795RPM
Old Apr 21, 2018 | 03:20 PM
  #34
FlashGuy's Avatar
FlashGuy
Looks like the RPM belt supercedes the blue micro-v belt. Should be good. I track the blue belt with no issues. I also drive in the bitterly cold north. No squeaks on cold starts, which is like 5 months out of the year.
Old Apr 21, 2018 | 03:36 PM
  #35
Dan G37's Avatar
Dan G37
Wheres the best place to start when placing the new belt in? I'm about to install the new idler pulleys tomorrow and install my new belt. Was wondering which pulley is best to start with. Thanks!
Old Apr 21, 2018 | 03:40 PM
  #36
FlashGuy's Avatar
FlashGuy
I'd start by releasing the belt. There is a video on youtube for it. This gives you free reign to work on the pulleys without tension on them.
Old Apr 21, 2018 | 05:11 PM
  #37
Entcee's Avatar
Entcee
If you are doing the tensioner as well, leave that for last. I installed the idlers, then the belt, then the tensioner.
Without the tensioner you have a little more room and because the belt goes behind the tensioner, it just makes it easier.
Just be sure the belt is in the grooves on the lower left (passengers side) as it can be hard to see.
Old Apr 22, 2018 | 12:46 AM
  #38
Dan G37's Avatar
Dan G37
Thanks man
Old Apr 22, 2018 | 02:35 AM
  #39
jpowersjr2's Avatar
jpowersjr2
Yeah I read on here that Bando OEMs the belts for Nissan/Infiniti. Not sure if anyone else can verify.
https://www.myg37.com/forums/g37-cou...tine-belt.html
Old Apr 22, 2018 | 01:11 PM
  #40
Dan G37's Avatar
Dan G37
Ive heard the same about Gates belts, would love to know which one it is.
Old Apr 22, 2018 | 01:28 PM
  #41
Dan G37's Avatar
Dan G37
Hey Entcee I just replaced my tensioner as well and was wondering if this is normal.
My tensioner line is in range but when I started the car it is now out of range. Is this normal?
Old Apr 23, 2018 | 09:20 AM
  #42
Entcee's Avatar
Entcee
Interesting.... It should be between the left 2 marks. If I remember right, mine was just barely to the left of the middle mark (after engine start). It is still in spec, but if the belt stretches at all, it might not be.
Did you get the Gates tensioner?
Libster
General Tech Questions
Nov 6, 2019 05:54 PM
Libster
Jul 22, 2019 03:23 PM
microwave
Nov 14, 2013 11:08 AM
ecn113
Dec 5, 2008 10:18 AM
Trader_J
32
Mar 6, 2008 03:38 PM
