P1093 code returns again days later
oh story gets better. Of course the dealer replaced the head. A head which was supposedly populated with 'all the goodies'. Turns out a few years ago, Nissan stopped populating the heads with the actuators (found this out from a second source who I should have gone to originally to resolve the problem, but I wasn't aware of them at the time). So, when the dealer replace 'the head' in a blanket attempt to replace all the things that could be wrong and cause the P1093, they replaced everything but the ONE thing that was actually causing the problem. In my case, an actuator with an intermittent problem. Also, from the sheets, it was obvious what a different person did the job from the one who actually did the actual daignosis. So 'the guy who did the diag thought the head was populated, guy who did the work saw the report to 'replace the head', each did his own job.
The dealer replaced the actuator, and so far, everything is working fine now . . . .
so yah, a MASSIVELY fraggin expensive job for what should have been an actuator replacement (plus diag time)
First speak to the Infiniti Service Manager and the General Dealer Manager for some financial adjustment.
If not satisfied write a letter with copies of your dealer receipts to your credit card company for improper diagnosis and poor workmanship.
Also contact Infiniti Customer Relations if necessary
Good luck
Telcoman
