NEED HELP!! vibration when dropping RPM
Old Feb 26, 2018 | 11:08 PM
linkzk's Avatar
linkzk
Hi everyone,
Please help me.
My Q50 with VQ37 has vibration problem. I did a lot of search but nothing found.
I stop the car and move shift to P. I accelerate the RPM to 3000 and then release the gas pedal to let the RPM drop. This vibration happens at 1500 RPM and then gone.
This vibration happens only when the car is idling. This vibration happens only when RPM is 1500. This vibration happens only when RPM is dropping from higher to 1500. No vibration when RPM accelerates from lower to 1500.
I know this is G37 forums but the engine is the same.
Can anyone give me ideas about this problem? I went to dealer and they said this is normal. I really don't think this is normal.
Thanks.
Old Feb 26, 2018 | 11:09 PM
JSolo's Avatar
JSolo
Just say no!!!!!
It's not healthy to free rev the engine without load.
Old Feb 26, 2018 | 11:13 PM
linkzk's Avatar
linkzk
Originally Posted by Jsolo
It's not healthy to free rev the engine without loud.
Hi Jsolo,
Thanks for your reply. This is a mere coincidence. I accidentally pushed the gas pedal and noticed this problem.
Old Jul 27, 2018 | 05:41 PM
johnnychobani's Avatar
johnnychobani
I have the same problem. I guess it’s normal? 🤔
Old Jul 27, 2018 | 06:45 PM
slartibartfast's Avatar
slartibartfast
No-load revving to redline is not recommended, otherwise, don't worry about it.
When you say vibration, do you mean An individual part (i.e. heat shield) vibrates or do you mean the engine/transmission vibrates?
Old Jul 27, 2018 | 09:55 PM
johnnychobani
No, not to redline. Just revving pass 1500rpm, let's say 3000 and let it the rpm drop. It will hesitate/shake( it feels like the cars about to stall out) at around 1500 and then back to idling normally. Prob just need an idle relearn? I did cleaned out the TB and installed a CAI about two weeks ago. I also read that it could be the oil on the filter messing with the map sensor? Hmm who knows...
Old Jul 27, 2018 | 11:42 PM
slartibartfast
MAF sensor. These are not Hondas. Yeah, check the MAF again and perform the idle relearn.
slartibartfast
Jun 4, 2018 04:51 PM
justinc7100
Feb 8, 2018 08:06 PM
justinc7100
Dec 18, 2017 04:26 AM
justcin9877
Nov 29, 2017 11:18 AM
smashhell
34
Jan 7, 2011 10:51 AM
