clutch slave cylinder bleed
Old Feb 25, 2018 | 08:07 PM
Davpal's Avatar
Davpal
anyone tell me how to do this ? i have bled them on front wheel drive cars , just wandered where the bleeder drain is ?
Old Feb 25, 2018 | 11:16 PM
Gio37's Avatar
Gio37
Not sure if this is what you are looking for but hope this helps
look at 1:20
g/l
Old Feb 26, 2018 | 12:05 AM
JSolo's Avatar
JSolo
Just say no!!!!!
I do a simple gravity bleed followed a traditional bleed. The gravity bleed gets rid of the fluid in the line itself. The traditional bleed refreshes the little bit of fluid remaining in the slave.
To do the gravity bleed just open the bleeder nipple. Make sure the reservoir does NOT go dry. Two to three refills of the reservoir should be sufficient. For the traditional, I do about 3-4x where the pedal is pumped slowly several times then I open the bleeder screw. Top off the reservoir and you're done.
AlvaroJCeballos
47
May 9, 2019 01:34 PM
Mike@Czp
Engine/Intake/Exhaust
1024
May 25, 2018 11:28 AM
ewuzh
Apr 7, 2017 09:44 AM
PongSanity
Engine, Intake and Exhaust
Nov 29, 2016 10:27 PM
