Why are the coups prone to rear sub frame bushing leaks?
Old May 1, 2018 | 08:19 PM
staskz's Avatar
staskz
Originally Posted by kidtronix
Anyone have photos of what to look for? I have 17K on my 2015 coupe. Guess I'll have to get under there and check things out. Terrible roads around here the last year or so. This winter's made them even worse.
Old May 1, 2018 | 09:21 PM
1971442w30conv's Avatar
1971442w30conv
well at least the problem is consistent. That photo is exactly like my coupe and it happened within days
Old May 1, 2018 | 09:28 PM
1971442w30conv
You would think Infiniti would design a serviceable repair. Ford does the same on the 04 thru 09 F-150 upper control arms and the 2 wheel drive front rotors. until just recently if you needed rotors they came with wheel bearings, upper control arm had to be replaced with ball joints.
Old May 2, 2018 | 12:12 AM
Gio37's Avatar
Gio37
....just in case you have'y seen this quick fix
Old May 2, 2018 | 06:47 AM
The Pope's Avatar
The Pope
^ I was getting ready to suggest this!!!!
Old May 2, 2018 | 01:41 PM
Entcee's Avatar
Entcee
Mine has recently blown. Will be getting it fixed at some point.
Old May 2, 2018 | 01:42 PM
reNeglect's Avatar
reNeglect
Not good for the drivetrain and driveshaft as the slop under load could wear the U joints faster
Old May 2, 2018 | 03:26 PM
Lego_Maniac's Avatar
Lego_Maniac
SOHO did mine for $500, IIRC, including the bushing.
Old May 2, 2018 | 04:15 PM
Entcee's Avatar
Entcee
Yeah, I was just there and Matt told me the same. I am definitely not going to attempt it myself!
Old May 2, 2018 | 04:32 PM
Lego_Maniac
I'm a big DIY guy, but for $400 in labor? Considering I'd be doing this myself, in the garage, with hand tools, it would take me the whole day. $400 for labor is a deal!
Old May 2, 2018 | 04:37 PM
Entcee's Avatar
Entcee
I agree completely. If I have the tools, I generally DIY... with the exception of suspension components.
Old May 2, 2018 | 06:49 PM
staskz's Avatar
staskz
i recently had mine replaced with whiteline, huge difference.
Old May 5, 2018 | 09:46 PM
Entcee's Avatar
Entcee
Seems like most people here use Whiteline or Z1 bushings. Any reason to get one over the other?
