What is best aftermarket chip or software for G37?
Old Jul 28, 2017 | 08:00 PM
kroy's Avatar
kroy
Originally Posted by Victory
yeah, that's what the tip-in is. how much accelerator movement corresponds to how much throttle. It's electronically controlled. In the X models when you go into snow mode it actually reduces the accelerator pedal sensitivity to make it easier to accelerate without slipping. The Q50 also has an eco mode that likewise reduces the sensitivity.
Personally, i enjoy driving like a maniac
Dude, I had to come back and tell you guys. So I just had Ark Grip exhaust put on my car. Just the drive back, I felt like the aggressive tip in has diminished a bit. I feel like I can give the car my usual light pedal and it won't jerk my head back.
I feel like my car may have just needed supporting mods for the tune(i really should have gotten exhaust first). I'm going to pay attention next couple days and see if it's just a placebo.
Old Jul 29, 2017 | 09:13 AM
Victory's Avatar
Victory
Originally Posted by kroy
You kinda lost me there. I put it in while I had around half a tank left. My octane should have already been around 93-94 because I put in a couple gallons of 110 over the weekend.
So with 1/4 bottle of torco(8oz added to 10 gal), it should have boosted me about 4 octane numbers. So I'm assuming I'm at around 96+ octane on the conservative side.
It probably raised it 4 points = 0.4 octane numbers
A gallon of straight toluene in 10 gallons of 93 octane would get you about 95 octane. There's no way 8 oz of anything is getting you 96+
Old Jul 29, 2017 | 10:44 AM
Crazyirish's Avatar
Crazyirish
Yep, Especially considering the torco is basically just 110 octane fuel by itself.
(edit)
Curious though, Torco's own blend chart suggests otherwise. I wonder...
http://torcoracefuel.net/2-docs/acce...r-ratio-93.pdf
Old Jul 29, 2017 | 11:08 AM
slartibartfast's Avatar
slartibartfast
That chart does not indicate straight Torco octane but one could probably infer it from the chart.
I checked MSDS and it lists 2,2,4-trimethylpentane (80-100%), Methylcyclopentadienyl Manganese Tricarbonyl (0.1-10%) and naphthalene (0.1-5%). The first one is plain old isooctane which has octane of 100. Naphthalene is 90 Motor octane, I don't have Research number but it will be roughly 10-15 number higher. The manganese compound wasn't tested in API Project 45. Formula One outlawed manganese in fuels in the Nineties due to toxicity but it sure made astronomical turbo pressure values possible.
Chemical manufacturers must list each chemical in a mixture on the MSDS. They are allowed to fudge proportions to protect recipe, thus the ranges listed above.
Old Jul 29, 2017 | 01:53 PM
Victory's Avatar
Victory
Yeah, stuff would have to be like 500-600 octane to give you a 3 octane number boost in at a 1:160 ratio.
Old Jul 29, 2017 | 02:37 PM
slartibartfast
Where are you getting 160:1 ratio?
Old Jul 29, 2017 | 04:50 PM
Victory's Avatar
Victory
8 oz in 10 gallons...
Old Jul 29, 2017 | 06:19 PM
slartibartfast
We must be looking at different charts. The linked chart doesn't show an 8-oz in 10 gallon entry. Are you inferring from the five gallon line?
In addition, is that 8 fluid ounces or mass ounces?
Old Jul 29, 2017 | 08:08 PM
Victory's Avatar
Victory
In response to this
Old Jul 30, 2017 | 01:04 AM
kroy's Avatar
kroy
I was just basing my numbers off what torco claimed.
