Loud squealing noise ONLY when on reverse?
Old Apr 26, 2017 | 03:32 PM
NoPantsAllowed's Avatar
NoPantsAllowed
I can't be the only person who has experienced this with the coupe.
whenever I move in reverse, it makes a loud squealing noise. It een louder when I'm on a hill or after it rains. Happens a lot usually kn the begining, thought after reversing for some time the squealing noise does subside a bit.
I did a lot lf research with the general consensus being that it happens to most of the g37 coupes.
Has anyone experienced this? and has anyone found a solution? there has GOT to be a solution to this some how!!
Thanks in advance
Old Apr 26, 2017 | 08:28 PM
square965's Avatar
square965
Ugh, I have this problem. My solution is to just reverse at full speed without touching my brakes until the last second.
Old Apr 26, 2017 | 09:03 PM
If it's coming from the brakes you might try a little caliper grease on the brake pad backing plates.
Old Apr 26, 2017 | 09:43 PM
G37xS-Life's Avatar
G37xS-Life
My did something similar but moving in the forward direction. I checked the brakes, the wheels and etc. What made my 2012 G37xS coupe squeal was the drum brakes (e-brake). I ended up having to adjust it so that it doesn't rub. Since then, my coup has been squeal free.
I hope this helps.
Old Apr 26, 2017 | 11:33 PM
ItsRamsey-G's Avatar
ItsRamsey-G
I had this problem and it drove me nuts. Once I changed brakes and rotors it was gone A friend of mine used grease but it came back eventually. Still worth a shot
Old Apr 27, 2017 | 12:06 AM
NoPantsAllowed
Thanks for the response fellas.
I've tried the grease on the breaks, and I even installed brand new brakes. Still the same problem.
To the poster above, the ebrake situation sounds quite interesting. Can I ask how you found that to be the problem? And would I have to take it to the shop to ask the worker to see the ebrake? Or is it something I can do on my own?
Lets pray this is the cause of it!
