Looks like 2013's arent immune from rear timing gasket failure
Old Feb 3, 2017 | 01:41 PM
  #121
Emper's Avatar
Emper
Need help!!! I am in Toronto area, Canada. . I have a 2009 g37 sport sedan 6mt and just had this happen. (rear timing gasket leak) I bought an aftermarket protection plan so all i have to pay is a $100 deductible. The work is being done this Monday by infiniti. Infiniti swears that the gaskets to go back in are paper. I have given them part numbers 13555-jk21a and 13555-jk21b and they say these gaskets are paper also and do not fit. If i put them in, then the aftermarket company said they will not warranty the product if it happens again. My question is whether the original gaskets and these uodated gaskets are both paper?? What should I do. Is there a different part number for these Gaskets inn Canada. Really need to hear from Canadians who had this done esp. to see what part they used. Thanks. I have to Monday morning to figure this out. posting this under 2 threads, hope that is ok
Old Feb 3, 2017 | 01:51 PM
  #122
Victory's Avatar
Victory
They shouldn't just be replacing the gasket, they should be replacing the entire cover assembly with part # 13500-EY03B. There are no provisions in the factory service manual for replacing just the gasket.
Old Feb 3, 2017 | 02:19 PM
  #123
Emper's Avatar
Emper
They are replacing everything, they are ordering new parts in today. Do you think the parts ordered will include these metal gaskets??When someone posted pictures of the above mentioned parts 13555-jk21a and 13555-jk21b, the gaskets appeared to have a metal undercoat if that makes sense. Those gasket part numbers at the infiniti dealer I am dealing with have these part numbers in stock and they are all paper according to the service manager. Just dont know what to think. If metal ones were going in I might keep the car but if it is the same paper ones, I think I will sell it as I can see this problem happening again outside warranty. Thanks
Old Feb 3, 2017 | 10:54 PM
  #124
Victory's Avatar
Victory
Those gasket part numbers are for the g35. The most current assembly should have the revised gaskets
Old Feb 14, 2019 | 01:49 PM
  #125
teahead's Avatar
teahead
Can anyone confirm if the replacement gaskets are the same paper type or have been reinforced new design?
I'm just curious; not that I have an issue (yet).
Old Feb 24, 2019 | 12:24 AM
  #126
teahead's Avatar
teahead
So far NO ONE has proven the updated timing cover gasket is something OTHER than paper
If this were to happen to me and out of warranty , I would try the CZP gaskets.
Old Feb 25, 2019 | 11:12 AM
  #127
nero209's Avatar
nero209
So I’ve been reading a lot about this on the 370z forum, I just found this and this is what the guy said:
Finally ripped the car apart today, oil galley gaskets were all intact, looks like this motor got the updated versions because they were some composite metal material instead of the old paper style. Anyway i didn't take it apart for no reason even though the gaskets didnt fail, the ****ty fasteners did. On the upper galley two fastener were less than hand tight. So this is why i was getting low oil pressure drops, but no ecm codes (p0011,p0021)
2012 370z
Old Feb 25, 2019 | 05:00 PM
  #128
slartibartfast's Avatar
slartibartfast
So, not a gasket failure, rather a builder/rebuilder failure. Lok-tite will cure that.
Old Feb 25, 2019 | 05:05 PM
  #129
teahead's Avatar
teahead
No ECM codes but low oil pressure?
Uggh...looks like I need to install an oil pressure gauge.
Old Feb 26, 2019 | 09:17 AM
  #130
RMB5190's Avatar
RMB5190
I could've swore that Motorvate DIY had a video on how to test your oil pressure so you can anticipate whether or not this is creeping up on you.
Old Mar 1, 2019 | 05:41 PM
  #131
conkus805's Avatar
conkus805
I had no codes but had my oil pressure tested because I had a feeling the car wasn't running correctly. sure enough the oil pressure was low, not terribly so but it was below factory spec. plus I had low compression in cylinder 3. so instead of replacing the gally cover I just swapped in a motor from a 2015 z. got the motor for 1k$ with 19k miles with all accessories attached, free shipping, and installed for a total of 4k$ all said and done.
Old Mar 1, 2019 | 06:07 PM
  #132
nero209's Avatar
nero209
Whoa that’s a steal. Where did you find that engine? I’m looking at one with 16k miles but it’s going for 2,500$
Old Mar 7, 2019 | 01:59 PM
  #133
conkus805's Avatar
conkus805
just look on ebay, there are plenty of motors that are way cheaper than 2500$. mine was also a complete motor with all accessories attached took 3 days from drop off to pick up to get the motor in and tuned. the company I got my motor from was Tae used auto parts, based in Florida. just search for a 2015 vq37vhr engine, there will be plenty available. I just searched and there is one that has 36k miles for around 1200$.
Old Mar 7, 2019 | 02:08 PM
  #134
conkus805's Avatar
conkus805
https://rover.ebay.com/rover/0/0/0?m...2F282913596631
check out this link
Old Mar 17, 2019 | 06:29 PM
  #135
PNW_IPL's Avatar
PNW_IPL
Latest revision rear timing cover 13500-EY03B
updated OEM reinforced gaskets 13533-jk21b 13533-jk21a
my water pump is failing at 77k. How do i talk nissan into replacing just the galley gaskets while im there vs repacing the entire cover?
