Blue smoke
Old Nov 16, 2016 | 12:15 AM
crb1468crb's Avatar
crb1468crb
Originally Posted by jpg37
Blue smoke on startup usually indicates leaky valve stem seals. While the car sits small amounts of oil leak past the seals and then burns off when first started.
My problem is only upon cold startup
Old Nov 16, 2016 | 12:16 AM
crb1468crb's Avatar
crb1468crb
Originally Posted by rsingerG37
Start small and replace the PCV valves.
What would you do next?
Old Nov 16, 2016 | 05:34 PM
Victory's Avatar
Victory
Don't worry about replacing the PCV valves yet. Just pull them out and look behind them to make sure there isn't a puddle of oil sitting there. If it's relatively dry, the PCV isn't the issue and it's more likely to be something like valve seals.
